Author Topic: Philips Monitor???  (Read 3761 times)
dreamakuma
  • Last login:July 08, 2010, 02:14:54 am
Philips Monitor???
« on: January 05, 2009, 03:09:59 am »
I have an X-men arcade cabinet that's being restored. I open the back to look at the monitor only to find The label says Philips MO8X.  Did philips make arcade monitors or I am I dealing with a modded T.V?
Newbie in working on cabs, expert in playing, breaking, moving slowly, and overall failing at them too.
patrickl
  • Yo momma llama
    • PocketGalaga
Re: Philips Monitor???
« Reply #1 on: January 05, 2009, 03:20:57 am »
Philips makes the tube that other companies used in their monitors. I think you will find the name of the monitor somewhere else on the frame or circuit board.
dreamakuma
« Reply #2 on: January 05, 2009, 06:06:48 am »
Well There is nothing anywhere else I can see that says any name or brand or company. I was wanting to know because of this:
http://i249.photobucket.com/albums/gg221/hadokenakuma/100_1611.jpg
I need help knowing what the problem is with the left side. it rolls up and is significantly darker(Still playable and I can see the left side,just rolling shades up it). I have no idea how to cap and less of an idea on sotering(I have been without glasses for 5 years due to lack of insurance and now have them but missed a lot of trades) so all help would be apretiated very much. I think I'm going to talk to a T.V repairman about the issue but that takes money, which after the cab and the wife, is runnin' slim. sorry for the typos, i had to re-type this in a hurry.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: January 05, 2009, 11:07:04 am »
And you read this first?
http://forum.arcadecontrols.com/index.php?topic=62016.0
dreamakuma
« Reply #4 on: January 05, 2009, 06:16:14 pm »
There is nothing on the chasis. NOTHING. no letters, numbers or anything on that board.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: January 05, 2009, 06:25:06 pm »
And you first visited the monitor ID websites and looked at the pictures of the various monitor chassis?
Kevin Mullins
    • Me on Myspace
« Reply #6 on: January 05, 2009, 06:29:07 pm »
I need help knowing what the problem is with the left side. it rolls up and is significantly darker(Still playable and I can see the left side,just rolling shades up it). I have no idea how to cap and less of an idea on sotering soldering
Sounds like a common capacitor problem.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #7 on: January 05, 2009, 09:47:36 pm »
i.e.  faulty boost cap .  supplies the 150-200v source for the rgb output xistors .
 typical value will be 4.7-22 uF / 160-250v   (suggest use 105 degree caps )   ;)
qrz
SirPeale
  • Green Mountain Man
« Reply #8 on: January 05, 2009, 09:50:08 pm »
If I were a betting man, I'd say...K7000, with a bad C57.
dreamakuma
« Reply #9 on: January 06, 2009, 01:19:20 am »
Well since I'm an idiot(I'll be the first to admit it), I don't think I'll be doing any DIY repairs on the monitor, so I can live longer. I'll talk to a tv repairman, but if there is no luck/price is overly costing, Would anyone know of a good monitor that will hook up to arcade pcbs or a way to connect them to ordinairy CRT pc monitors/TVs that's under $200? I'm a dummy who is still getting his feet wet in this hobbie. Thanks for all the help.
SirPeale
« Reply #10 on: January 06, 2009, 10:47:52 am »
You'd spend hundreds of dollars to avoid spending $10 and a little work?
dreamakuma
« Reply #11 on: January 06, 2009, 12:39:53 pm »
I am completely new to electronics.end of story. I never got any expiriance in the field, And the threat of a shock is a bit much considering I have a heart problem. So I can't solder, and I am not allowed to mess with the tube(wife & doctor). I even had to ask a friend to help me remove it safely so I could see the chasis. So when I see the big board with all this stuff on it, it's uh, scary. with my lack of expriance, I fell I'm more likely to make mistake, and have to replace something that is more than expensive, and then make another mistake(i.e ---smurf up---). I don't like blowing my money for a backdoor solution, but it seems to be the better for me. If there's an idiots guide to this stuff , or a for dummies book on this matter(completely in depth) I might feel more comfortable with the monitor, but I know nothing of eletronics. My other cab is completely user friendly because I'm so new at this stuff(Dreamcast,x-arcade, 17"LCD, and two sets of pc speakers. if it's broke, replace on the cheap.).
SirPeale
« Reply #12 on: January 06, 2009, 01:05:19 pm »
Take the proper precautions and you won't have to worry about getting shocked.
The only times I get shocked is if I take shortcuts.
Get/make a tube discharge tool.
Get a soldering iron and practice on something broken.
Once I couldn't do this stuff either, but with practice it slowly came to me.
