Author Topic: trying to find a 17 - 19 inch non - widescreen lcd monitor at good price.  (Read 1515 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
Hi guys, Im looking for a 17 or 19 inch lcd monitor. The catch is it has to be a 4:3 (non widescreen) ratio.
I want to put it in a vertical bartop cab and dont want to pay alot.
« Last Edit: January 01, 2009, 01:20:13 am by rlemmon »
briktop11b
  • Last login:December 24, 2009, 12:19:33 am
cmoses
Check your local craigslists, a lot of people sell theirs cheap when they get a new widescreen.  With the holidays just passing I am sure there should be some on there.  Plus you can actually see it in person before you shell out any money.
rlemmon
Thanks guys  :)
Blanka
Well, you might be looking, but they DO NOT EXIST!
17 and 19 inches are all 5:4 as they are 1280x1024 pixels (or 16:10/16:9 since recently)
You need 20 or 21.3 inch. Those sizes are available in 1600x1200. Big plus: they are all S-IPS or S-PVA so better image quality.
15 inch was available in 1024x768, so that is another 4:3 option.
Cheap-ass solution: there are 4:3 TV's with 20 inch LCD's with 640x480 or 800x600 resolution, but O BOY there is bad TN panels in them.
Forgot to read you post very well: You talk about VERTICAL placement. That makes things even worse. There is no escape! You have to spent more bucks on a SPVA or SIPS panel. TN looks ---steaming pile of meadow muffin--- mounted vertical. Check out a second hand DELL 20 or 21 inch with 176/176 or 88/88 viewing angles or better, or a Samsung 213T or a 214T. HP also has some old nice 1600x1200 displays. And there is the Eizo S2000 and S2100. This segment is probably your only hope.
Well, now I look at it, the Dell is a good deal. You won't regret that panel.
« Last Edit: January 05, 2009, 02:00:27 am by Blanka »
