Author Topic: Maybe I'm thick, but can someone help out?  (Read 3200 times)
patchboston
  • Last login:September 02, 2020, 09:31:04 am
« on: December 24, 2008, 11:57:25 am »
Greetings!
I have a Bob Roberts drop-in power supply that I'd like to hook up to an interlock switch.
How would I go about wiring this in?
thanks,
--Dave.
« Last Edit: January 14, 2009, 07:10:18 am by patchboston »
Own: Pac-man, TMNT, P.O.W.
Level42
Re: Maybe I'm thick, but can someone help out? (wiring - interlock)
« Reply #1 on: December 24, 2008, 01:42:52 pm »
Before the AC on/off switch, but I really don't like that drawing as it only switches off one lead of the mains. If the plug gets reversed, you will have voltage on your inline. Then again, I don't think American grounded plugs actually can be reversed (They can overhere, so every switch is double contact). I'd suggest double contact anyway, for safety, also on the door interlock.
« Last Edit: December 24, 2008, 01:47:51 pm by Level42 »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: December 24, 2008, 03:25:29 pm »
Im not sure you want to interlock the power supply. Usually the safety interlocks are along AC line in, to cut all power. Is there a reason you want to cut power to the power supply, but not the rest of the AC distribution?
NO MORE!!
patchboston
« Reply #3 on: December 26, 2008, 05:37:22 pm »
Busy xmas...didn't have time to log on!
ok, so the interlock runs even before it gets to the components of the power supply? Got it.
that crossed my mind, but I wasn't 100% sure.
So how would I go about wiring it in now?
Run the ac cord's hot, neutral to the interlock, and then run the corresponding wires to the board?
thanks,
--Dave.
Level42
« Reply #4 on: December 27, 2008, 11:42:48 am »
Yes but stay behind the fuse at all times, preferable behind the filter as well.
patchboston
« Reply #5 on: December 27, 2008, 12:47:31 pm »
I'll make sure to do so, thanks!
SavannahLion
« Reply #6 on: December 28, 2008, 09:36:09 pm »
They're not supposed to be reversed, but there are a lot of wiring problems that can result in reversed wiring. Older homes don't have three prongs so severing the third prong is very common. A lot of home owners feel they can replace a simple wall plug without issues. I've been in places that have had crossed wiring, no grounds, and even one that used a 30 amp wall socket on a 15 amp circuit. The cottage I lived in had all of that, didn't even have a proper GFCI in the bathroom and one bedroom was wired entirely into a different apartment (wanna guess where I put all my computer equipment?  >:D ).
In any case, wire with expectation for the worst case scenario. Use a double contact. Be safe.  :cheers:
Or you could always use one of those wall socket circuit tester thingies (I got mine from Rat Shack, but I can't find it now). Check every socket you plug into.
patchboston
« Reply #7 on: January 14, 2009, 07:21:02 am »
I'm probably going to update this thread whenever I have a question (if thats ok with everyone)...
I just bought a new Tenma 21-7935 from MCM (soldering noob here)...
is this the solder I should consider? I'm going to start repairing a g07 (caps, flyback,etc.)
Rosin "60/40" = tin = lead?
http://www.radioshack.com/product/index.jsp?productId=2062715
seems like a good all around diameter.
also, someone mentioned on klov that the large gray filter cap on a G07 should be discharged, and some even said they'd do this with a lightbulb?
Or even a screwdriver, but that destroys the screwdriver..
can someone shed some light on the subject? I know how to discharge a monitor with a hv probe or bob robert's type discharger, but thats about it!
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #8 on: January 14, 2009, 07:53:11 am »
I use a normal screwdriver to discharge the filter cap on G07s and never had one damaged. I suspect that folks who are seeing damage are using mini-screwdrivers and maybe the tips are getting chipped.
EDIT: Solder looks OK to me.
Working: Not Enough
Projects: Too Many
Progress: None
Ken Layton
  • Guru
  • Technician
« Reply #9 on: January 14, 2009, 08:49:32 pm »
Yeh that's great solder. You linked to 64-009 which is the 8 ounce spool. I use 64-005 which is just less of it on a roll.
Those two numbers are the best all-around solder to use on many applications.
I've been using 64-005 for over 20 years. I go through a roll every two months.
yes you can discharge that large filter capacitor on the Electrohome with a common 60 or 100 watt incandescent light bulb.
patchboston
« Reply #10 on: January 15, 2009, 07:32:24 pm »
ok, cool.
So back to the lightbulb thing... just touch the bottom end of the lightbulb to the two leads, at the same time?
