Author Topic: Newbie question: How much time ...  (Read 967 times)
dkubarek
  • Last login:February 25, 2011, 01:00:32 am
« on: December 23, 2008, 08:47:27 pm »
Hi all,
I have a computer with windows XP and want to do the following: Install Mamewah, MAME, total sheller and a rom sorter. I also have ini files, but I know I'll need to edit them to fit my computer directory. (They are copied from another computer). I also want to configure 20 buttons and two joysticks. (X-Arcade stuff, and I'll mostly use their defaults.) And I want Mamewah to run on startup. I ask how long this takes because I plan to do all of this Christmas eve in the hopes of then taking a newly built arcade box to my nephews that night for Christmas. Is this a few hours of work or much more? I'm new to this, but I know a bit about computers. Still, not much. Am I in over my head or is this doable? Thanks
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
Re: Newbie question: How much time ...
« Reply #1 on: December 23, 2008, 09:11:37 pm »
Well of course the answer is "It depends"  ;)
Have you installed MameWah before? If not, it might be tricky to set up (it was for me, and had to spend a couple of hours tweaking things)
I've never used instant sheller, and took the easy way out: I made a shortcut to Mamewah and placed it in the startup folder; windows boots and then launches mamewah .. but you can still see the taskbar for 1.5 seconds or so.
As for configuring the buttons, you can do that via MAME's global settings, and should only take a few minutes.
So it's do-able, in a few hours. Maybe  :dunno
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
TOK
  • The Game Always Wins
« Reply #2 on: December 23, 2008, 09:46:23 pm »
If I was on a deadline like that, I'd use either MaLa (or AtomicFE), even if you decide to go back and do MAMEWah later for yourself. Its a great front end, but not as intuitive to set up since you're configuring text files. Its not hard, but confusing the first time. I had some issues with it not liking the way I had my directories setup, but then when I used a third party setup tool for it, everything worked fine. That kind of thing.  ;D
The newer front ends are set up just like a regular Windows app with tabs and makes the process a bit simpler.
dkubarek
« Reply #3 on: December 24, 2008, 12:25:10 am »
I gave Mala a once-over. Any downside to the program? I just know Mamewah is popular and very customizable. I have ini files, so it shouldn't be a real bear to set Mamewah up, but I'll emphasize "shouldn't." Thanks.
