Author Topic: SOLVED! WG 4600 Vertical Collapse help  (Read 2239 times)
Tenn_pin
  • Last login:January 01, 2014, 06:57:02 pm
« on: December 23, 2008, 12:46:16 pm »
Did a recap from Bob Roberts, but still have VC.  I have reflowed most all solder joints and checked connections with DMM.  After searching this site, I found where some of the transistors can go bad, mostly, TR305 and TR306.  I can pull them, but what am I looking for and how do I test them with the DMM?  Is there something else I should be looking for?  How can I go to our local electronics supply store and tell them what TR I need?  Can they usuall cross reference the number on the part?
Sorry for the chain of questions, but I feel I am chasing my tail>
R
« Last Edit: January 17, 2009, 02:04:42 pm by Tenn_pin »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: WG 4600 Vertical Collapse help
« Reply #1 on: December 23, 2008, 05:21:12 pm »
this vert sweep uses discreet components rather than an ic .....
check r322, c313,c310, c306
tr303, tr307 as well as tr304, tr305
a schematic can be found here : http://www.cityofberwyn.com/manuals/WG-4600.pdf
the voltages you measure should be close to those listed,  when properly operating
qrz
Tenn_pin
« Reply #2 on: December 24, 2008, 10:41:46 am »
Can this be done with the input board removed?  It would be easier if it was not in the way, but does that change any values on the board?
R
Tenn_pin
« Reply #3 on: January 17, 2009, 02:02:40 pm »
Turned out to be TR306.  I measured to resistance values with a known working board and found a large difference.  Ordered the part from Bob Roberts and the XY board worked.  I did have to change one of the resistors on the solder side to a jumper, but that did not take much time.  Thanks for the help.
qrz
Re: SOLVED! WG 4600 Vertical Collapse help
« Reply #4 on: January 18, 2009, 10:55:09 pm »
faulty vert pre driver .
tnx for posting the fix . good job  ;)
qrz
