Author Topic: problem loading nintendo64 and visual pinball games  (Read 3731 times)
coinopman
  • Last login:June 09, 2009, 09:18:53 pm
« on: December 22, 2008, 10:32:14 pm »
I installed  MaLa using unclet's setup and I get "ERROR" "attempt to open file failed." Any ideas what I missed? Mame runs gr8. I have only installed vpinball and pj64 with hack so far.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: problem loading nintendo64 and visual pinball games
« Reply #1 on: December 22, 2008, 11:19:27 pm »
What version of Project 64 are you using?  If you are using version 1.7.0.25 or later, the command line needs to be:
Code: [Select]
"%path%\%rom%.%ext%"
Earlier versions of PJ64 cannot have the quotes as I recall which creates major problems for roms that have spaces in the rom name.  If this isn't your issue, consider posting screenshots of your first two screens of Mala's PJ64 configuration.
I also run VP successfully.  If you post your configuration for this, I may can help.  I do not use UncleT's guide so my way may be a little different.
coinopman
« Reply #2 on: December 22, 2008, 11:29:31 pm »
That fixed the project64 problem. Now to figure out how to send a screenshot of vpinball. Question: i haven't installed any other emu's yet but is the same exe problem i had with pj64 the same on some other emu's?
SGT
« Reply #3 on: December 22, 2008, 11:37:17 pm »
The command line that I use for VP is:
Code: [Select]
%path%\%rom%.%ext%
The rom extension should be VPT.
The rom path should point to the folder where your tables are.
coinopman
« Reply #4 on: December 22, 2008, 11:52:07 pm »
That is what I have. When i select say, black knight, it opens visual pinball blank screen.On basic tab executable = C:\VPINBALL\VPinball.exe.exe   Rom path = C:\VPINBALL\Tables execute tab - command line = "%path%\%rom%.%ext%"
SGT
« Reply #5 on: December 23, 2008, 01:05:59 am »
Was this is a typo?
As you can see in my post above, I don't use the quotation marks in my VP command line.  It may not matter, but I don't have them.
coinopman
« Reply #6 on: December 23, 2008, 09:03:05 am »
that is not a typo on executable. apparently that is not not. i took off the last exe on that line and got error code 2. i will reinstall vpinball and try again.
