Author Topic: Vertical Cocktail Cabinet - 100% COMPLETE  (Read 3234 times)
Hornpipe2
  • Last login:December 07, 2014, 02:09:52 pm
« on: December 21, 2008, 06:50:00 pm »
EDIT: Current status - complete - check here:
http://forum.arcadecontrols.com/index.php/topic,87731.msg1425676.html#msg1425676
I've got time off over Christmas and I'm using it to finally finish my vertical cocktail cabinet.  Based somewhat off Kyle Lindstrom's plans, with a couple modifications and a 19" TV.
The easiest way to follow along with the progress is to click here, as my recent work is fully documented with pictures.
http://greg-kennedy.livejournal.com/tag/arcade+cabinet
Feel free to comment!  I'll keep bumping this when I post more to my LJ.
« Last Edit: March 02, 2014, 02:02:03 pm by Hornpipe2 »
Hornpipe2
Re: Vertical Cocktail Cabinet
« Reply #1 on: December 22, 2008, 07:06:45 pm »
Click the link above for today's update: putting the TV in its place.
Franco B
« Reply #2 on: December 22, 2008, 07:28:43 pm »
J a quick FYI, most people generally (including me) are too lazy to follow a blog when the whole point of BYOACs PA thread is to blog your progress, especially when the blog is hard to follow/navigate.
Hornpipe2
« Reply #3 on: December 22, 2008, 07:57:50 pm »
All right, I'll probably just keep doing this until the whole thing is done and then put the highlights in this thread  :)
Franco B
« Reply #4 on: December 22, 2008, 08:13:20 pm »
That's fair enough if you want to do that. The main point of posting in this sub-forum (generally) is to get the help and advice from people who can aid you (if you need it).
I imagine (from what I have seen) that you will get replies to your blog but not generally replies that will help you.
If that's the case and you need no help (wish I was that lucky :)). great. I look forward to seeing the result.
Good luck with it  :cheers:
  • Last login:February 28, 2026, 04:55:22 pm
« Reply #5 on: December 23, 2008, 07:55:02 am »
bah... no pics...
Hornpipe2
« Reply #6 on: December 23, 2008, 07:12:34 pm »
OK you guys win, here are some pictures:
Here it is running Galaga:
and here is the cracked PCB of my keyboard hack caused by dropping a hammer in the machine :angry:
Now I will go drown my sorrows in Christmas alcohol while I lament the time I will lose trying to repair this thing without being able to actually remove the CPs.  I guess that's not so bad :cheers:
Hornpipe2
« Reply #7 on: March 15, 2009, 12:31:37 pm »
So I finally got back to this project.  Spent 30 minutes fixing up the keyboard hack (it took three little jumper wires to bypass the cracked traces), and then 2 hours playing instead of doing actual work on it : )
« Last Edit: March 02, 2014, 02:04:33 pm by Hornpipe2 »
Hornpipe2
« Reply #8 on: March 02, 2014, 02:01:08 pm »
By the way.  I did eventually finish this.
The complete write-up is here:
https://sites.google.com/site/cocktailcabinet/
And the "overview" video is here:
The information is slightly outdated.  The 1/8" glass shattered and I replaced it with plexi.
« Last Edit: March 02, 2014, 02:04:17 pm by Hornpipe2 »
