Author Topic: Soldering and button help  (Read 2257 times)
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
« on: December 19, 2008, 05:49:16 pm »
first im having allot of trouble doing a keyboard hack i cant solder the damn keyboard things please help?
I have a button and the screw thing wont go on?
SirPeale
  • Green Mountain Man
Re: Soldering and button help
« Reply #1 on: December 19, 2008, 06:59:19 pm »
It takes practice to solder.  If you've never done it before, you do NOT want to start trying with a keyboard hack.
If you have some piece of electronics that doesn't work anymore, practice on that first.
As for the button nut, just keep at it; if you get it crooked you can't thread them properly.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: December 19, 2008, 08:34:12 pm »
If you have any money you could use on a key encoder, buy one instead. Keyboard hacks are outdated to the point of being a last resort.
Buy an Ipac or KeyWiz instead.
Ed_McCarron
« Reply #3 on: December 21, 2008, 09:02:04 pm »
If its a newer keyboard PC board, with the compression connector strip?  Don't try to solder to it.  You'll need to scrape off the mask and solder directly to the traces.
Unless you just need to decode a few buttons, spring for the purpose built encoder of your choice.  You will be much happier.
ghettodish
  • Last login:October 21, 2017, 03:41:58 pm
« Reply #4 on: December 21, 2008, 09:25:04 pm »
You can learn how to solder here:
http://www.solder.net/technical/tips.asp
  • Last login:Today at 08:50:58 am
« Reply #5 on: December 22, 2008, 07:50:00 am »
Don't do a keyboard hack...
You could buy an Ipac, Keywiz, or some other encoder.
Or, if you really want to hack something, use a PC gamepad.  Lots of games accept joystick input, and for those that don't, there is a program called joy-to-key that will take your joystick inputs and convert them to keyboard inputs.
ghettodish
« Reply #6 on: December 22, 2008, 10:16:33 am »
Sidewinder gampad hack will save you a lot of headaches. I've done it a few times with gamepads I found for $1.50 each
http://arcadecontrols.com/arcade_staticx.shtml
shardian
« Reply #7 on: December 22, 2008, 10:37:34 am »
Your button nut may not be working because it doesn't go with that button. Once upon a time, I had a giant lot of used buttons. There were 4-5 styles of button nuts too. Some of the button nuts were not compatible with certain styles of buttons. Others worked, but I could tell they weren't a true match.
wooowman93
« Reply #8 on: December 22, 2008, 08:59:53 pm »
Everyone thank you for your help i got it working i used a keyboard and game pad to prevent ghosting
and the nuts went on after ALOT of tries
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: December 23, 2008, 11:40:24 am »
Just for the future, one way to line up the threads on nuts is to put the nut on as if you were going to screw it on, but instead gently and slowly turn it as if you were unscrewing it.  When you feel it "click" or drop, start screwing it on.  This only helps if the problem is lining up the threads, and sometimes there are two clicks per rotation and only one of them is the starting point.
Robin
Knowledge is Power
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
« Reply #10 on: December 24, 2008, 09:39:31 am »
I did a keyboard hack, but I'm cheap ;) Got the keyboard at a local surplus store for $1. Haven't had any problems with ghosting that I'm aware of. It was an older Gateway keyboard. I pulled out the encoder, and soldered cat 5 wire to where the ribbon cable went into the board. Ran those to some terminal strips I had on hand, and ran the wires from the joystick and buttons to there. Then I used a volt meter to map out the keys I wanted to use in MAME on the mylar grid under the keys. Didn't take too long, and I find it fun to tinker with stuff like that.
Jack Burton
« Reply #11 on: December 25, 2008, 06:01:02 pm »
Just for posterity:
- Sony PS1 Dual shock series H controllers can be hacked without soldering.
-  PC controllers can be found on ebay and hacked for less than $5
-  Most older console controllers can be hacked and adapted for parallel or seriel port use.
- People will sell pre-hacked controllers for less than $20
- random keyboard encoder sell on ebay for less than $20 if you're too cheap for a keywiz, I-pac, cthulu, etc.
