Author Topic: Cabinet with no power  (Read 2123 times)
johnnybleu
  • Last login:November 25, 2009, 01:27:02 pm
« on: December 14, 2008, 07:12:41 pm »
Hi all!
Newbie here with a cabinet question... Ok, so I picked up a Lethal Enforcers cabinet (converted from a SF2 cab), but it doesn't turn on. The cab and interior components are all intact (or so it seems) and in what I could consider to be excellent condition (just a little dusty).
Now, I plug the thing in and nothing happens. No fans run, no lights go on, monitor doesn't turn on, game doesn't boot up, nothing. The cabinet didn't have a plug when I bought it, but there was a weird 3-prong hookup behind it, just like on a PC. I assumed a plug for a PC power supply would work, so that's what I used. There's also a strange switch looking thing next to the hookup that says "5AMP"- it seems more like a kill switch, since I tried pushing and moving it every way and nothing happened. Doesn't feel like a regular switch.
So, I don't know if anyone has any idea what I should do next, or what kind of trouble shooting I should be attempting, coz I have NO clue.  :-\ Any help would be appreciated here!
Is there a power switch anywhere inside the cab? Shouldn't the fan on the power supply kick in once it's plugged in? Does it require a specific type of plug? Idea and suggestions are welcomed.
-JF
pinballwizard79
Re: Cabinet with no power
« Reply #1 on: December 14, 2008, 07:23:30 pm »
Perhaps the switch is bad.
Only way to know is to take the wires from the plug side & twist them to the ones going to the other side of the switch.....while its unplugged.
Then close your eyes & plug it in.
If you die do not blame me, thats just what I did on my machine when the switch went out.
Mauzy
« Reply #2 on: December 14, 2008, 07:32:13 pm »
Are you sure there isn't a hole one the top of the cab with a toggle switch in it? Feel around for it. It was three months till I realized my first cab had one - the guy I bought it from  never used the switch, just plugged and unplugged...
The 5 amp thing is probably a fuse.
johnnybleu
« Reply #3 on: December 14, 2008, 08:36:44 pm »
You know what, as soon as I read what you said about a hole on the top, I remembered seeing a round hole on the side with a button-looking type thing in it... I wondered what that was at the time, but now I know..... :banghead:
I feel stupid now, but it works like a charm! THANK YOU!!!
pinballwizard79
« Reply #4 on: December 14, 2008, 10:07:09 pm »
OMG
Kevin Mullins
    • Me on Myspace
« Reply #5 on: December 14, 2008, 10:11:21 pm »
You aren't the first one for sure.... by the way, that 5 AMP thingy is a circuit breaker.
Mauzy
« Reply #6 on: December 14, 2008, 10:24:44 pm »
Ha. Don't feel bad. I'm sure if you look through my earliest posts you'll find a couple like this. Give it 6 months and you'll be helping the new people too.
