Author Topic: BACK TO THE ARCADE BARTOP  (Read 94639 times)
dkssprs
  • Last login:February 23, 2023, 01:32:26 pm
    • Bub & Bob's BARTOP
Re: BACK TO THE ARCADE BARTOP-COMPLETED!!!!!
« Reply #120 on: June 11, 2009, 02:12:10 pm »
Yeah, it was gonna be on my Astro City Cab.  I can change the Sega Presents to something else you want! :D
What format would u like it in? (for maximus arcade)
i think we sould change SEGA presents with BTTA logo(back to the arcade).What you say? If you have better idea please try it...i trust you... :notworthy:
I am using maximus arcade frontend.  ;D
cboy
  • Last login:October 07, 2012, 02:09:29 am
« Reply #121 on: June 12, 2009, 03:48:17 pm »
how wide is your cab? I'm trying to decide if im going to do 2 player or 1 player on my bartop. I have a 15' LCD monitor so I think im gonna stick with 1 player. just trying to get a feel for my options...
i think i want a fighter setup thou..hmm
Sosetsuken
  • Last login:November 10, 2014, 02:13:46 pm
  • Da Daaah Da Daaah Da, Da Da Daaah Da
« Reply #122 on: June 13, 2009, 08:41:25 am »
Hey dkssprs,
Something like this? ;)
[youtube]EV8PRdrLaFs[/youtube]
Uploaded here mate:
Resolution: 640x480
Video Codec: Xvid
Audio Codec: MP3 192kb/s
Frame Rate: 29.97fps
:D
dkssprs
« Reply #123 on: June 13, 2009, 09:09:32 am »
My cabs cp is 45cm wide. I think that the 15" inch monitor is too small for 2players cab. But there is ebough space for 2 players.
dkssprs
« Reply #124 on: June 13, 2009, 09:12:36 am »
Sosetsuken i think that the BTTA logo sould be at the first screen of the video.(what you think??)
But if we go for the BTTA logo i think it sould be more bolded .....what you say?
Also what you say removing the reflection effect at the BTTA logo....(also here need your opinion)
« Last Edit: June 13, 2009, 09:14:24 am by dkssprs »
Haddock
  • Last login:August 21, 2009, 01:24:54 am
« Reply #125 on: July 23, 2009, 04:53:48 am »
Great thread, and a wonderful result.
I am in the process of building one of these too.  Can you please tell me:
* how did you power your lcd monitor?  Off the PC PSU?  Any photos of this?
* did you just use USB speakers?  1W per channel?  Did they work well?
dkssprs
« Reply #126 on: July 23, 2009, 12:20:58 pm »
Hello my friend and good luck with your project.
I powered the lcd monitor using the psu. I opened the psu and i mounted(if this is the right espression) a cable like this one
I cut it in the middle. Inside this cable are three cables...the one is the power cable the other is the groun and the other is the neutral.
Take these 3 cables and mount them inside the psu, at the three pins.
POWER SWITCH AND AC socket.
If you dont know how to mount them .....go to a electrician....its to easy for him to do that kind of work.
I hope i have help ypu.
Please feel free to ask everything....glad to help you.  :)
Haddock
« Reply #127 on: July 24, 2009, 04:24:10 am »
oh I see!  Thank you for your quick reply.  :cheers:
Your machine looks amazing.    :notworthy:
 I'm at the early stage, just cutting out the mdf, getting ready to paint.  I've got a 17in LCD ready, a pc for parts, a 450W PSU (hope that is enough? What did you use?), and some new speakers.
What did you use for speakers?
And did you use the same part of the PSU to power the floerescent tube (light)?  That requires 12v right?
Thanks again!
Haddock
« Reply #128 on: July 24, 2009, 05:04:44 am »
Actually, I've been thinking about it some more...tell me if I am wrong.  Generally speaking:
230v AC --> PSU --> 12v DC --> PC
My monitor has it's own power brick, so its:
230v AC --> LCD power brick --> 12v DC --> LCD
In your example photo above, you're taking your power cord and tapping into the 230v, and then I would be running it through a power brick to the LCD.  That's fine.
So I guess I have two options:
1. 230v AC --> PSU and LCD power brick --> 12v --> PC and LCD
2. 230v AC --> PSU --> 12v --> PC and LCD
If I do 1, I will need power brick, but it's easier to tap into AC like you did.
If I do 2, I won't need power brick, but rely on PSU for 12v DC supply.
I think I might do 1.
AM I RIGHT?  Or am I not making sense at all?   ;D
bratwurst
  • Last login:July 03, 2021, 10:51:34 am
« Reply #129 on: December 18, 2009, 04:51:46 pm »
I love the artwork and the cabinet.  Would you be willing to share the marquee and control panel artwork?  I'd like to do something in the same style, I love the marquee as is.  The control panel I'd need to modify heavily for my config.  I wouldn't know the first thing about creating those flames like you did for the tire trails.  I'd like to have those go direct into a trackball.
dkssprs
« Reply #130 on: December 24, 2009, 12:08:39 pm »
Of course mate!
i will give you a link tomorow cause i must find the artwork where i have saved it.
I will give you the cp artwork with and without the buttons layers so you can do anything you want.
I will also give you the marquee.
All the files will be in AI format...is it ok?
Merry Christmas everyone!!!!
« Last Edit: December 24, 2009, 12:40:13 pm by dkssprs »
bratwurst
« Reply #131 on: June 17, 2010, 09:41:28 pm »
wow late response by me... sorry.  are you still willing to share the artwork?  I'm definitely still very interested.  I'm just now getting close to where I can install them on my cab.
EDIT - nevermind, worked up something using the vector graffic here
« Last Edit: June 24, 2010, 12:58:11 pm by bratwurst »
dkssprs
« Reply #132 on: September 17, 2011, 09:12:51 am »
I am about making a refresh at my bartops look.
I will change the buttons to red and black.
I desperately want to convert my joystick (Mag-Stik S, black) from bat top to ball top.
Is there a way to do that?Any ideas?
here is my joystick
« Last Edit: September 17, 2011, 09:22:10 am by dkssprs »
dams511
  • Last login:June 16, 2012, 09:52:01 am
« Reply #133 on: September 17, 2011, 06:30:17 pm »
Hello
I am building the same project as you a BTTA mamecab.
I m lookinf for the video with the BTTA logo but the link is dead.
Do you have it ? Is it possible to have it ?
My project is in grey color. I wait for the panel in metal to finish it.
Sorry I can t help you for your question about the Mag-stik ( impossible to find it in France)
Thanks for your information in this forum. they have very help me to do my dream : a mamecab !
Louis Tully
« Reply #134 on: September 17, 2011, 07:18:54 pm »
« Last Edit: February 12, 2015, 04:55:24 am by Louis Tully »
dkssprs
« Reply #135 on: September 18, 2011, 04:36:31 am »
Hello
Hi mate.
Here is the link for the btta intro.
http://www.mediafire.com/?0rfo94v21f7r17s
dams511
« Reply #136 on: September 18, 2011, 04:59:45 pm »
Thanks for the link !! ;)
wrkey
  • Last login:March 17, 2022, 10:40:33 am
    • The Game Preserve
Re: Bub & Bobs BARTOP!!!->NBA JAM-->BACK TO THE FUTURE
« Reply #137 on: December 30, 2013, 11:32:15 pm »
Sorry to resurrect an old thread...
I would like permission to use this image and if possible to get the Vector graphic of it.  I am co-owner of 'The Game Preserve' in The Woodlands, Texas and we are a Pinball and Video Arcade.   I also happen to own a De Lorean and a member of the De Lorean Owner's Club of Houston.
I am planning on an event where the De Lorean Owners would bring their cars out (10 or more) and have a Back To The Arcade night.  If I could use the image it would be use for our Facebook page, website and posters.
Thanks in advance!
Rusty
www.gamepreservehouston.com
Hey dkssprs,
I was making a BTTF Themed cab, but have decided to take my cab in a different direction.
I have this which you could feel free to use, as I'm not using it anymore.
I have a Vector version of it if you would like it, so you can make it as big as you want.
Nice looking bartop btw :D
  • Online Online
  • Last login:Yesterday at 11:59:44 pm
« Reply #138 on: December 30, 2013, 11:59:01 pm »
Welcome aboard, Rusty.
Sosetsuken hasn't logged in for over a year.   :dunno
You might have better luck contacting him via e-mail -- go back to the post you linked and click on the icon under his username.
« Last Edit: December 31, 2013, 12:01:06 am by PL1 »
dkssprs
« Reply #139 on: December 31, 2013, 03:53:00 am »
Merry christmas everyone and happy new year!!!  :applaud: :applaud:
Here is the latest looking of my cab after a small refresh.
I changed the battops to ball tops and chang the swanw with concave buttons with the right colors (black and red)
before
after
bratwurst
« Reply #140 on: January 01, 2014, 02:14:57 pm »
Looks fantastic!  One of my favorite builds now even better!
