Author Topic: sounds  (Read 2381 times)
glyndawn
  • Last login:January 05, 2009, 03:37:09 am
sounds
« on: December 14, 2008, 04:33:12 am »
hiya all
ive got the machine up and running and its sweet love it
just carnt get the soundset to work can some one help
the sound set works when i play it from media player but when i tell mala to play them it wont any ideas
system01
  • Last login:March 04, 2023, 08:06:55 pm
  • System Idle Processes are the Devil's Playthings
Re: sounds
« Reply #1 on: December 14, 2008, 01:34:38 pm »
Are you talking about the list movement and action sounds?  If so:
SOUNDS & MUSIC
Enable Audio - Checked
The appropriate sounds are in the boxes?
If you press "play" and hear nothing then:
GUI > LAYOUT
Use Sounds from Layout - Unchecked
and
GUI > OPTIONS > DISPLAY DELAY
Either uncheck Enable Display Delay
or check GUI Sounds
I had a problem where long sounds would play but short (~1s) wouldnt.  Turns out the delay was longer than the short sounds.
Any help?
glyndawn
Re: sounds
« Reply #2 on: December 23, 2008, 06:29:50 am »
that sorted it thank you
