Author Topic: Pinout for HAPP Analog stick with trigger guard handle  (Read 1279 times)
jeffremiller
  • Last login:January 03, 2011, 05:55:16 pm
  • No matter where you go... There you are...
« on: December 11, 2008, 08:07:49 pm »
I have my stick (5k POT) and my UHID Nano.  Does anyone know the pinout on the Happ analog sticks?
"If all wishes were gratified, many dreams would be destroyed." - B. Banzai
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Pinout for HAPP Analog stick with trigger guard handle
« Reply #1 on: December 12, 2008, 01:01:11 pm »
Do you have a picture of it?
I'm just guessing, but: black is usually ground, and red is usually 5v+.  If nothing else, you can use that and a multimeter to figure out the rest.  (sometimes it might feel like you need a third hand, too.)
Robin
Knowledge is Power
jeffremiller
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: December 12, 2008, 06:52:10 pm »
Sorry, I didn't say I already looked at all the happs analog joystick exploded views looking for a pin out, or at least some info on how many pins and how they are arranged.
I was hoping for a pic of the harness, especially how it hooks to the base, and the plug end.
Just guessing, I'd think the analog side has four wires: gnd, 5v+, X axis, & Y axis, but there could be six with each axis having its own gnd & power inaddition to the sensor wire.  And the buttons end has three or four wires (assuming two buttons on stick): one for each button, and one common ground or two grounds with one for each button.  But I'd need more info to give you better info.
Or are the POTs not hooked up to any wires, and you are asking about how to wire directly to the POT?  The POTs should have three connections: the middle usually is the one for the axis, and the ends usually are for ground & power.
OT, how do you like the handle?  It looks... I don't know, like the guard is an added afterthought?
Robin
Knowledge is Power
jeffremiller
« Reply #4 on: December 12, 2008, 08:40:11 pm »
I agree on the guard... it was afterthought... but t was $20 on ebay versus 16o for a B-8.
 took your advise and have X & Y working on the nano.. just a matter for scale at this point.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: December 15, 2008, 03:22:50 pm »
Nice steal deal!  And glad to hear you got it working.   :cheers:
Robin
Knowledge is Power
