Author Topic: Can I use a Happ 3" trackball plate with an Imperial 3" ball?  (Read 2103 times)
AlanS17
    • AlanS17
I would like to flush-mount my trackball, but I need a Happ plate to do it. Can I fit an Imperial 3" trackball onto a Happ 3" plate?
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Can I use a Happ 3" trackball plate with an Imperial 3" ball?
« Reply #1 on: June 19, 2003, 07:48:29 pm »
yes you can... I did it with the non-flush plate... but the mounting holes are near-standard...
Rampy
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: June 19, 2003, 11:56:38 pm »
Yes, I used the flush-mount plate.  3" Trackball holes are standardized (size & location).
BTW, my Betson/Imperial TB leaves a little itty-bity bigger space around the TB lip than my happs TB; approx 1/16" diameter difference, so 1/32" space all the way around if mounted perfectly centered.
Robin
Knowledge is Power
AlanS17
    • AlanS17
« Reply #3 on: June 20, 2003, 12:02:00 am »
I kind of figured this was the case. That's why I asked. There's one more part I can order from Bob Roberts! I need to compile a list...
mccall
  • Last login:July 23, 2003, 03:58:39 pm
« Reply #4 on: June 20, 2003, 12:03:43 am »
I had to enlarge the holes on my Imperial to use the Happs boltless plate. Not much, just slightly. I'm not sure if I had an older model and that was the reason or if the newer ones also need this.
AlanS17
    • AlanS17
« Reply #5 on: June 20, 2003, 12:12:13 am »
Doesn't sound like a problem that a good mallet can't fix.  ;D
mccall
« Reply #6 on: June 20, 2003, 12:18:04 am »
Yeah, some friendly persuasion from a large mallot would probably have worked ;-)
It wasn't much, just a shaving actually, and it was only on the top inch or so of the top of the housing. It took all of 30 seconds to do with a snug fitting drill bit. I read where you can "shave off" the black paint around the inner mounting bolts of the Happs plate and that will also work, but I read it after I shaved my TB with a drill bit so I do know personally whether it works or not.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: June 20, 2003, 12:27:58 am »
Hmm, I had to do that with my wico TB, but not my betson TB.  FWIW, the betson I have is a "golden tee" "high lip" TB.
Robin
Knowledge is Power
mccall
« Reply #8 on: June 20, 2003, 12:07:17 pm »
Mine was not the high lip version, maybe there's the difference.
