Author Topic: Got dimensions of Simpsons (or equivalent) bezel?  (Read 1212 times)
jasonbar
  • Last login:September 04, 2025, 11:58:58 pm
  • Dr. Inferno
    • The Infernolab
« on: December 09, 2008, 04:46:52 am »
Howdy-
I'm nearing completion of my MAME cabinet & am ready to lay out artwork for the screen bezel.  The cabinet started life as a Simpsons (or other equivalent Konami 4P quarter-eater) & it was a gutted 2-slot Neo Geo when I got it.
I just want to make sure that I get the proper width & height dimensions to get a nice fit.  I think I've been working too long in aerospace & forget how loose tolerances in the real world can be!
Not looking for the artwork or viewable area, since I've shoehorned a 27" monitor in there--just the outside width & height, please.
-Jason
Franco B
Re: Got dimensions of Simpsons (or equivalent) bezel?
« Reply #1 on: December 09, 2008, 06:01:24 am »
You work in aerospace but dont know how to use a tape measure?  ;D
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #2 on: December 09, 2008, 11:25:35 am »
Ouch!   >:D   :)
Sure, I can measure the space between the cabinet left/sides, but what's the typical desired gap to leave?
And for the height, how deep ought the bezel insert into the slot at the top?
Thanks,
-J
Franco B
« Reply #3 on: December 09, 2008, 11:44:50 am »
Just playing with ya jasonbar, I work in aerospace too  ;)
I suppose it depends on the bezel that you are using, are you using a Happ 27" bezel or are you making your own?
You can see the dimensions of the 27" Happ bezel [here].
If you are making your own you could base if off those dimensions.
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #4 on: December 09, 2008, 12:27:06 pm »
Thanks, Franco.
I guess this brings up a good nomenclature question that I've been thinking about recently.
I already have a solid black contoured bezel that contacts & frames my monitor (the same one you link to).
What I'm looking for is the *flat* piece of glass or plastic that goes in front of the monitor and has decorative & informative artwork around it: the bezel!
Am I mis-naming one of these items, or are both commonly called a "bezel"?
Thanks,
-J
