Author Topic: Small cabinet cp design  (Read 1143 times)
weasel
  • Last login:March 08, 2017, 05:02:06 am
« on: December 08, 2008, 09:54:34 am »
I have a small poker cabinet that was turned into an arkanoid.  But now Id like to turn it into a 60-1 but would like some knowledgeable opinions on a good control panel.  I assume I only need three buttons and a stick but I would like to add a spinner just trying to figure out where everything should be placed.  As info the cp is 19 inches long.  Any advice appreciated
captainpotato
  • Last login:November 11, 2016, 06:10:59 am
  • I'm a tapir!
    • Tapir Design
Re: Small cabinet cp design
« Reply #1 on: December 10, 2008, 08:13:47 am »
My CP is 44cm wide (17.3") and whilst I have to admit that the cabinet has yet to be used in its current iteration, I've fitted all of this on. The you take a look at the most recent photo here, this should give you some idea of how I've done it. The start buttons and credit button aren't on the same surface, but I don't see that there's any need to have them all grouped with the game controls.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #2 on: December 10, 2008, 12:40:52 pm »
Agreed. Check out the cabinets we build for an idea of how controls can be mounted in a limited space, yet still look uniform. Although we've never done a panel so small with a trackball, simply dropping it in place of where player 2 would usually be should be fine, assuming the surface panel is deep/wide enough to accommodate the trackball you intend to use, and you account for the large interior space the trackball housing takes up inside the control panel section. I highly reccommend the U-Trak from Ultimarc for it's 'contained' housing, easy mounting and lack of a need for a mounting plate.
Bender
« Reply #3 on: December 10, 2008, 12:55:57 pm »
I am working on this and the cp is only 15" wide the U-track is the only full size trackball that would come close to fitting in mine and I still thad to modify it a bit to squeeze it in
the game play is quite comfortable except the joystick is a little too close to the left side
« Last Edit: December 10, 2008, 12:57:48 pm by Bender »
