Author Topic: I have system 22 running by vivanonno but keys are c x z any way to remap these?  (Read 3207 times)
tyweed
  • Last login:March 09, 2008, 01:29:03 pm
I have vivavonno running system 22 roms which are ridge racer and rave racer. Thesed games are killer ! One major problem though i have mame setup on my six buttons on my cab but vivanonno uses c for gas and x for brake anyway i can change these somnehow? I use the i pac but would i be better reconfiguring vivanonno somehow please anyone who has dealt with this let me know what you did
rusolinio
  • Last login:December 14, 2010, 08:21:22 pm
if you have an ipac you could use the winIPAC program to remap your buttons to match that of the vivanonno config.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
If he replies after these 5 years, then he is the world's most patient poster.   He mentions the ipac option, btw.
MKChamp
  • Last login:February 07, 2024, 02:45:53 pm
  • Stil around.
Hahaha
5 years and he never even threw in a *Bump*
Maybe AHK wasn't created 5 years ago...or he found it.
rusolinio
I had a similar issue very recently and found it whilst searching through the many threads regarding ridge racer. So, i thought i'd revive his issue for others to see.
I own an original stand up ridge racer cab which stopped working recently. I used vivanonno to judge the emulation of the game (not bad, but no comparison to the original) with a standard cp.
I suspect the board is fried in the RR machine as it no longer boots up, so i wish at some point to re-create  it in my cab via emulation.
Ive had the steering wheel and pedals out and all use 10k pots. I know there are a few ways of connecting my controls to a pc (U-hid, A-pac interface) but im obviously going to use the vivanonno emulator to re-create the ridge racer series.
My issue now is that i cant figure out how to configure vivanonno to use my steering wheel and pedals?
Could i configure the steering controls with the A-pac/u-hid sofware first, and then have the prog run in the background when i start vivanonno to emulate the joystick control?
Anyway, sorry for my utter ignorance in not introducing myself, being my second post 'n all.  I go a little scatty when video game obsession creeps in......
TAG
  • Last login:May 23, 2014, 05:52:05 pm
As I recall, Vivanonno accepts analog input, so you should have no trouble using the A-Pac or U-Hid with it.  As I also recall, the emulator doesn't have the normal "coin up" and "player start" options (I think you hit Q for the service switch), so it might not be as straightforward to work into the original cab.
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
rusolinio
You have to press 'Q' for both the service switch (when pressed together with 'T' ) and credits.  Will be a bit of a swine for sure.  But hopefully it will still allow me to use my cab for the purpose it was designed for. Cheers for the input.
