Author Topic: Constant MaLa error messages  (Read 2146 times)
PsychoAU
  • Last login:October 04, 2020, 12:27:19 am
« on: December 05, 2008, 08:39:24 pm »
I have been getting constant error messages with MaLa and it is about to drive me up the wall...
One error I get sometimes when I try to start a game:
2008/12/05  17:14:24.93   Error: Object Class: TfrmMain, Object Function: Starte, Exception Class: EAccessViolation, Exception Message: Access violation at address 0044D1A8 in module 'MaLa.exe'. Read of address 00000004
This other happens every time I try to close MaLa and return to the desktop
2008/12/05  17:36:52.76   Error: Object Class: TPopupList, Object Function: FormClose, Exception Class: EAccessViolation, Exception Message: Access violation at address 0044D1A8 in module 'MaLa.exe'. Read of address 00000004
I am absolutely about to throw this thing through the window.  What could be causing this?  I am running XP.
loadman
  • Moderator
    • MaLa
Re: Constant MaLa error messages
« Reply #1 on: December 07, 2008, 12:18:21 am »
It sounds like your windows is getting upset.
I would consider a reinstall before throwing out the window.
Can you copy your mala setup to another PC to see if you have the same issue?
