Author Topic: Flaky colours on monitor?  (Read 2270 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: December 05, 2008, 12:17:50 pm »
Hey all.
I just have a general question..
I have a 20" arcade monitor that works great, but have shifting colour intensity..some on
red some on green etc. It usually follows the image on the screen...like Out Run where
the road suddenly changes colour depending on the other colours, like sky, trees and rocks.
Any idea what could cause these instabilities? Caps, transistors?
Thanks a lot!
Nicholas
« Last Edit: December 05, 2008, 12:57:00 pm by AE35 »
grantspain
Re: Flaky colours on monitor?
« Reply #1 on: December 05, 2008, 01:04:46 pm »
could be just overdriving the colours,have you tried bringing the contrast down a bit
AE35
« Reply #2 on: December 05, 2008, 01:52:04 pm »
Hey!
Well, I've had it running for several hours now, and it really seems to also change
over time....when I came up the image was mostly blue. Even though all the color-pots
are turned completely down. I'm giving this monitor 4V through an amp. Which makes
me wonder...did any machines ever use standard 0.7V on the RGB?
Still, it seems very flaky. I'm I'm getting annoyed at these arcademonitors :)
grantspain
« Reply #3 on: December 05, 2008, 02:09:12 pm »
range from 1v to 3v on rgb
what model is this?
AE35
« Reply #4 on: December 05, 2008, 04:05:06 pm »
Well, I just measured the voltage it's around 2,5V
When there's a lot of white on the screen the overall contrast goes down
and become somewhat yellowish. As soon as the object that makes the picture
bright starts to go away the overall high-contrast comes back. As if it can't handle
peak-white...or close :)
I have no idea right now what monitor this is. I can't find anything on the chassis but it's
from a generic cab, not a dedicated.
Nicholas
grantspain
« Reply #5 on: December 05, 2008, 04:17:12 pm »
post a pic of the chassis
sounds like an abl fault
AE35
« Reply #6 on: December 06, 2008, 04:53:09 am »
Hey! I found a sticker on the chassis:)
Wei-Ya Model /2820H
Thanks,
Nicholas
grantspain
« Reply #7 on: December 06, 2008, 05:34:42 am »
there is a problem with a lot of the wei ya/rodotron chassis whereby the abl pot is not set up correctly,if you are getting problems when the screen changes e.g its goes bright then quickly goes to normal then i am sure this is the abl pot
i think rickn will know exactly how to proceed with this
