December 20, 2025, 10:20:57 am
Does anyone know how to enable mouse input in mamewah, so i can use a trackball to play marble madness?
Uh, I do not believe mouse input in MAMEWah is the problem.I use mamewah and use my trackball to play marble madness.I believe the lack of trackball support is a MAME configuration issue. You just don't have mame config'd right.
Changing mame.ini to:mouse 1will activate the mouse / trackball for all games.
...Create a marble.ini file and put it in your cntrl directory and use the same line in it. You'll need to activate the controller directory through mame.ini
Thanks guys. I would play all trackball games, but some spinner games, i'd still want to use the joystick. You can use the joystick as well as the trackball, even if trackball's turned on, can't you?
