Author Topic: Working Sega Saturn Emu!!  (Read 4157 times)
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
« on: June 18, 2003, 11:53:08 pm »
i found a working Saturn Emu,
looks like it was compiled between numerous
Emulators and a FE and stuff. looks strange,
but i tested it and it works great. heres where
you can grab it. http://www.geocities.com/ssemupro
click the little square - link under to download it.
**IF I SHOULD NOT POST THIS PLEASE LET ME KNOW**
it contains NO roms or information on obtaining them or anything bad.
« Last Edit: June 20, 2003, 07:59:37 am by Syxx »
tyweed
  • Last login:March 09, 2008, 01:29:03 pm
Re:Working Sega Saturn Emu!!
« Reply #1 on: June 19, 2003, 12:28:55 pm »
liks no longer working and i tried a search with no lluck. anychance you could send me the file i'd love to try a saturn game
Syxx
  • Bling Bling
« Reply #2 on: June 19, 2003, 01:54:02 pm »
just go to
and theres a blue square thing click that and it seems to download
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: June 19, 2003, 11:07:21 pm »
Be aware that geocities has a very low max through per hour (IIRC, close to 6 MB per hour).  Depending on the size of the file, that could be a max of one download per hour (if it was the same size as mame currently is).  If you can't get it, wait an hour and try again, then wait another hour and try again, until you can finally get it @ 3 AM.  :P
Robin
Knowledge is Power
tyweed
« Reply #4 on: June 19, 2003, 11:35:35 pm »
one problem with this emulator its in japanese.........  everything!  kinda makes it hard to work.Let me know if someone has luck getting it going maybe they can post some tips
Syxx
  • Bling Bling
« Reply #5 on: June 20, 2003, 08:00:31 am »
check my other topic, i just made one with info on how to get it up and running.
spectre
  • -- banned --
  • Last login:April 07, 2004, 08:45:11 am
  • -- banned --
« Reply #6 on: June 20, 2003, 11:02:05 am »
there's plenty of saturn emulators...lol
-- banned --
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #7 on: June 20, 2003, 11:18:40 am »
if i have teh cds that i bought for my saturn, can i just make iso's and play? is this the same as making a psx iso?
It's all about the Pentiums
spectre
  • -- banned --
  • -- banned --
« Reply #8 on: June 20, 2003, 12:06:54 pm »
depends on the emu, some have a proptietory format
-- banned --
Syxx
  • Bling Bling
« Reply #9 on: June 20, 2003, 12:07:16 pm »
ya as far as i know it should work, just copy it as a bin and cue file and create a TOC following the instructions in readme.txt i also made another post explaining how to run stuff.
i beleive you can run from the CD Drive if you open SSE and file/CDROM but you still need a TOC file matching that game, so the iso/bin is the best route. plus you may get slow down running from a drive.
be aware i dunno how much it supports. i'v only tried like 2 games, but its the first Satrun Emu i'v ever seen run anything at all at more then 5FPS, this gets 45-60FPS for me.
jakejake28
« Reply #10 on: June 20, 2003, 12:07:34 pm »
i am referring to this emu
spectre
  • -- banned --
  • -- banned --
« Reply #11 on: June 20, 2003, 12:27:45 pm »
i haven't used this one so i dunno
-- banned --
GoldenBear
  • Last login:March 27, 2004, 07:27:48 pm
  • El Oso de Oro
    • Bearz Inn
« Reply #12 on: June 20, 2003, 01:25:21 pm »
Is it just me or is the Readme included in this zip/rar all garble?
Such as:
GoldenBear
spectre
  • -- banned --
  • -- banned --
« Reply #13 on: June 20, 2003, 01:56:11 pm »
open it in another text reader
-- banned --
GoldenBear
  • El Oso de Oro
    • Bearz Inn
« Reply #14 on: June 20, 2003, 02:11:38 pm »
Well, opened it in word and it recommended i use a chinese font....translated that with babelfish and got some very broken english.
Better than that garble for sure but still very difficult to understand.
GoldenBear
Syxx
  • Bling Bling
« Reply #15 on: June 20, 2003, 02:57:34 pm »
oops that readme isnt right one, i forget where i got mine from it explained it all...
let me look for it and i'll post its contents.
Syxx
  • Bling Bling
« Reply #16 on: June 20, 2003, 03:00:45 pm »
Heres the Translated readme, im sure this ones better.
Instructions
1. Rip your favorite game using cdrwin(as a raw 2352 byte sector image), put
   both image and cue in the same directory as girigiri saturn.
   OR
1. Run glaunch.exe with a full pathname(e.g. If you have all the files in
   c:\girigiri, then run the program as c:\girigiri\glaunch). Setup everything
   how you want it, click the big image, then when Girigiri starts, close the
   program(you only have to launch glaunch once). You may also want to adjust
   the AREA option in base.ini to the region of the cd that's in your
   cdrom(see step 3).
   Now just run gsaturn with the "-DISK" switch(e.g. gsaturn -DISK). Make sure
   your saturn game is in your first cdrom(if you have cdrwin handy, just
   check to see which one is first in the list).
   This mode does work(I got it working in Win98 using VirtualPC and on my
   Win2k setup), but it may not(I wasn't able to get it running properly in
   my WinXP setup). Just make sure your aspi drivers are up to date, etc. Skip
   instructions 2-7
2. run gentoc on the cue file(e.g. gentoc bloop.cue), this should generate
   a file called toc.bin.
3. Now edit base.ini, and change DISK1TOC so it points to the toc.bin file
   you just created(you shouldn't need to change this as by default, it's
   toc.bin). And change DISK1IMG so it points to game's image(e.g. bloop.bin).
   Lastly adjust AREA to the region of the game:
   1 = Japan
   2 = Taiwan/Philipines
   4 = US/C
   5 = Brazil
   12 = Europe
   etc.
4. Now run glaunch.exe with the full pathname. (e.g. If you have all the files
   in c:\girigiri, then run the program as c:\girigiri\glaunch)
5. In the Launcher, adjust the settings how you want them(it should all be
   pretty straight-forward), then click on the huge image
   ("Click here when you are finished").
6. Girigiri Saturn should basically start up, and go through all that bios
   spiel like it does on a real saturn.
7. You only have to run glaunch once. So next time(unless you want to change
   some settings), just run gsaturn with the "-i" switch(e.g. gsaturn -i)
8. If the game doesn't load, it could be an emulator issue, or perhaps a
   bug in gentoc. You could always try adding your game in games.dat and
   tweaking the settings.
9. Emulator settings, save ram and backup ram files are all located in settings.
