Author Topic: Mame Control mapping for exit button?  (Read 35903 times)
brpadington
  • Last login:July 17, 2012, 01:19:10 pm
« on: November 26, 2008, 11:48:37 am »
I have a mame cab running ubuntu and sdlmame. Is there any way i can set up a key combination to exit a game back to the frontend? i looked in the tab menu and did not see and entry for escape. any ideas? :dunno
Doctor Ugs
  • Last login:May 14, 2011, 02:56:58 pm
  • Arcade addict since 1980
Re: Mame Control mapping for exit button?
« Reply #1 on: November 26, 2008, 12:53:33 pm »
i have 2 buttons linked to exit, that way you must press both to exit.
check the 4th post in this thread
http://forum.arcadecontrols.com/index.php?topic=78515.0
« Last Edit: November 26, 2008, 12:56:56 pm by Doctor Ugs »
"My memory is so bad,
Alzheimer's would be an improvement!"
My Project Thread, 2 Mame Cabs.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: November 26, 2008, 01:56:43 pm »
...i looked in the tab menu and did not see and entry for escape. any ideas?
You want to look for "UI Cancel" in the Input (general), User Interface menu; the default key is esc but the input is not called that. ;)
To map mame to require two buttons without rewiring (IOW, mame software vs the via hardware), after you press enter ("UI Select" default key), press both buttons you want.  Slightly more info on remapping at mameDev FAQ.
Not that there's anything wrong with hardwiring it.  I'm too lazy to, though, and just remap.  And use ctrlr file to store the remaps.
Robin
Knowledge is Power
brpadington
« Reply #3 on: November 29, 2008, 11:09:48 am »
Awesome! Thanks!
