Author Topic: Attract Mode  (Read 3827 times)
OnezerO
  • Last login:August 23, 2011, 11:17:01 pm
  • I'm not a llama!
Attract Mode
« on: November 25, 2008, 07:47:42 pm »
Loadman, I started to mess around with the Mala attract mode utility and I can't seem to get more than 16 LED's to show up.
Under the LED Config option I am choosing Hardware 1 with Mala 32 LED's and just the show button option checked, however after I assign all 32 (button) LED's only LED 1-16 show up and none of the assigned LED's from 17 to 32 show up in the layout design.  Is there something I am doing wrong?
As always than you for your dedication and help.  I love the new life that you have given to Mala.  Keep up the excellent work!!!
loadman
  • Moderator
    • MaLa
Re: Attract Mode
« Reply #1 on: November 26, 2008, 05:34:25 pm »
It used to work.
I will have to check I have not broken something.
Have you tried an older version?
OnezerO
  • I'm not a llama!
Re: Attract Mode
« Reply #2 on: November 26, 2008, 05:43:44 pm »
I was unaware that there is an older version.  I thought that only 1 version existed.
I downloaded the "Mala Attract 1.0" from the Mala website, which is the one I am having this problem with.
If there is an older version please show me where I can find it and I'll try it out.  Thanks!
loadman
  • Moderator
    • MaLa
Re: Attract Mode
« Reply #3 on: November 27, 2008, 05:32:03 pm »
Forget that.
Sorry I did not read your mail properly.
There is a tutorial here on how to use it:
http://malafe.net/files/download/Mala_Attract.doc
OnezerO
  • I'm not a llama!
Re: Attract Mode
« Reply #4 on: November 27, 2008, 08:10:13 pm »
Thanks for the quick reply Loadman.  I feel like a dumbass, I already had the instructions from the first time I downloaded the app several months ago, but I forgot about it.
Since, I'm on a report PC away from my CAB I'll have to wait to get back home to try it out, but I am sure everything will be okay.
Thanks again.
loadman
  • Moderator
    • MaLa
Re: Attract Mode
« Reply #5 on: November 27, 2008, 09:54:57 pm »
Yeah it is a bit tricky initially to get it to read your setup.
But once you have done that it is a lot of fun
