Author Topic: KT-2914F Squealing as I turn up brightness  (Read 2892 times)
jconstanza
  • Last login:April 23, 2009, 02:28:02 pm
« on: November 25, 2008, 05:02:30 pm »
I have a KT-2914F that is on a pattern generator, when I have it on an all white screen their is a squealing sound and at the same time their are lines going from left to right across the screen. Also as I turn up the brightness on the flyback the noise gets worse. Cap kit, replaced R206, R207, IC201 & have swapped more than one flyback. Same thing
grantspain
Re: KT-2914F Squealing as I turn up brightness
« Reply #1 on: November 25, 2008, 05:18:13 pm »
the white lines are flyback lines when the screen volts/brightness is too high
some monitors do squeal without a video signal and high brightness-frequency whistle,maybe your pattern generator puts out a signal that the monitor does not like
jconstanza
« Reply #2 on: November 25, 2008, 05:20:46 pm »
But I have used this generator on other similiar chassis and I have had no problem with it.
grantspain
« Reply #3 on: November 25, 2008, 05:31:37 pm »
maybe a noisy coil,does any tapping of the chassis affect the noise
jconstanza
« Reply #4 on: November 25, 2008, 06:09:10 pm »
No not really. I hit it with a screwdriver and nothing.
grantspain
« Reply #5 on: November 25, 2008, 06:36:00 pm »
i know someone that has a wei ya chassis that does the same,we never got to the bottom of the problem
maybe something to do with the b+ being unstable or set incorrectly but tbh this is one for the experts like rickn,qrz or ken layton
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #6 on: November 26, 2008, 11:37:37 pm »
white pic = max beam current = higher load on pwr supply .
should not have retrace lines on white screen
to set white balance ( video signal must be present )
turn brightness and contrast to min
adjust screen ctl ( on flyback - bottom post) to point that image is just barely visible.
then slowly back off till it disappears .
return brightness and contrast ctls to desired levels
qrz
