Author Topic: SOLD! FOR SALE WORKING DUAL PIII MOBO PERFECT FOR MAME! SOLD!  (Read 2810 times)
SnApRoLl
  • Last login:November 14, 2010, 05:26:50 pm
« on: November 24, 2008, 02:55:48 pm »
SOLD!!!
Thanks,
Shawn
« Last Edit: September 03, 2009, 03:44:30 pm by SnApRoLl »
SnApRoLl
Re: FOR SALE WORKING DUEL PIII MOBO PERFECT FOR MAME!
« Reply #1 on: November 28, 2008, 08:57:09 am »
Bump
« Last Edit: November 28, 2008, 11:13:12 am by SnApRoLl »
SnApRoLl
« Reply #2 on: December 01, 2008, 09:24:02 am »
BUMP for a lower price.
I will let this board go for $40.00 but will NOT go lower.
Buyer pays all shipping costs. Again this board was tested and it works great!! However it is being sold as used and there is no warranty of any kind.
Thanks,
Shawn
SnApRoLl
« Reply #3 on: December 02, 2008, 01:56:41 pm »
I have had a few P.M.'s with questions about the FSB etc..
And I found this site that has all of the specs on this board.
Here are the specs.
Tyan Tiger 200T S2505TDNGR - motherboard - ATX - Pro133T
General
MPN: S2505TDNGR
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 24.4 cm
Compatible Processors: Celeron, Pentium III
Processor Socket: Socket 370
Chipset Type: VIA Apollo Pro133T
Max Bus Speed: 133 MHz
BIOS Type: Award
Storage Controller: ATA-100, ATA-100 (RAID)
Processor
Installed Qty (Max Supported): 0 ( 2 )
Memory
Supported RAM Technology: SDRAM
Supported RAM Integrity Check: ECC
RAM Installed ( Max ): 0 MB / 1.5 GB (max) - DIMM 168-PIN
RAM Technology: SDRAM - ECC - 133 MHz
RAM Features: Unbuffered
Video
Graphics Controller: PCI - ATI RAGE XL
Video Memory: SDRAM
Video Memory Installed ( Max ): 4 MB ( 4 MB soldered) / 4 MB (max)
Telecom / networking
Networking: Network adapter - Ethernet, Fast Ethernet - integrated
Features
BIOS Features: APM 1.2 support, ACPI 1.0 support, power failure recovery (AC loss resume), DMI 2.0 support
Manual Settings: CPU frequency
Hardware Monitoring: CPU core temperature, CPU fan tachometer, system voltage
Sleep / Wake Up: Keyboard wake up, wake on modem (WOM), RTC (real-time clock) wake up, wake on LAN (WOL), mouse wake up
Manufacturer's product description
The Tiger 200T is an ideal choice for cost-effective server applications. Featuring a 1U-capable design, this system board provides the power and form factor necessary for today's demanding server environments. With its integrated IDE RAID, VGA and dual LAN connections, the Tiger 200T is perfectly suited for desktop and rackmount servers. There are plenty of PCI slots for adding storage and network controllers, as well as DIMM sockets.
Expansion / connectivity
Expansion Slot(s):
    * 5 ( 5 ) x PCI
    * 2 ( 2 ) x processor - Socket 370
    * 4 ( 4 ) x memory - DIMM 168-PIN
    * 1 ( 1 ) x AGP
    * 1 ( 1 ) x ISA
Storage Interfaces:
    * ATA-100 - connector(s): 2 x 40pin IDC
Interfaces:
    * 1 x storage - floppy interface - 34 PIN IDC
    * 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style)
    * 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
    * 1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
    * 1 x serial - RS-232 - 9 pin D-Sub (DB-9)
    * 2 x USB - 4 PIN USB Type A
    * 2 x network - Ethernet 10Base-T/100Base-TX - RJ-45
    * 2 x USB
    * 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
    * 2 x mainboard - internal signaling - 3 PIN internal power
Miscellaneous
Cables Included:
    * 1 x floppy cable
    * 2 x IDE cable
Software Included: Drivers & Utilities
Compliant Standards: Plug and Play
Package Type: Retail
Manufacturer warranty
Service & Support: 3 years warranty
Service & Support Details: Limited warranty - parts and labour - 3 years - carry-in
Ciao
Listed on Ciao since : 30/01/2004
Thanks for looking, :)
Shawn
« Reply #4 on: December 02, 2008, 02:23:22 pm »
i just laugh cause you mis-spelled dual  :)
Bondo
  • Last login:June 09, 2010, 01:59:23 am
« Reply #5 on: December 02, 2008, 04:49:55 pm »
What levels of raid does this do? I might be interested if it can do raid 5.
SnApRoLl
« Reply #6 on: December 02, 2008, 06:30:15 pm »
It will only support  IDE RAID Levels 0,1, and 0+1. Allot of older server mobo's only support RAID1.
But like I said it's an older board. RAID 5 is mostly used with the faster sATA bus.
Thanks for looking though :)
Shawn
« Last Edit: December 02, 2008, 06:38:03 pm by SnApRoLl »
SnApRoLl
« Reply #7 on: December 02, 2008, 06:37:03 pm »
Fixed. Thanks for pointing that out. I didn't realize that LOL
SnApRoLl
Re: FOR SALE WORKING DUAL PIII MOBO PERFECT FOR MAME!
« Reply #8 on: February 12, 2009, 11:58:57 am »
BUMP.
I know someone trying to build a MAME machine on a budget can use a good mobo at a cheap price.
Thanks,
Shawn   :)
Ummon
  • Trade Count: (+13)
« Reply #9 on: February 13, 2009, 09:28:47 pm »
The specs says it has an AGP slot, but I don't see it.
Yo. Chocolate.
Stephen Hawking
ken_cinder
  • Last login:October 22, 2010, 10:38:18 pm
« Reply #10 on: February 13, 2009, 09:47:41 pm »
Yep, there's no AGP slot there only 4xPCI. The onboard video may be AGP, it wouldn't be the first motherboard I've encountered that had AGP onboard with no AGP slot. Manufacturers can't be pretty retarded sometimes.
Your video card doesn't play a big role with MAME anyway, but this could be a hinderance if it's uses were for other emulators that do HLE graphics emulation.
Wanted - TMNT artwork (CPO, Sideart, and Marquee)
Aero Fighters artwork (CPO and sideart)
Items for sale ChaseTheChuckWagon Vendazzle
SnApRoLl
« Reply #11 on: February 14, 2009, 09:32:22 am »
« Last Edit: February 14, 2009, 09:21:23 pm by SnApRoLl »
SnApRoLl
« Reply #12 on: February 14, 2009, 09:23:18 pm »
It's on board AGP 4megs to be exact.
Shawn
Ummon
« Reply #13 on: February 15, 2009, 06:19:49 pm »
Yeah, that's what I figured - a P4 of mine is like this, also - but in the posted specs for the expansion slots, it says 1xAGP, and so thought I'd ask.
Yo. Chocolate.
Stephen Hawking
SnApRoLl
« Reply #14 on: February 20, 2009, 01:47:05 pm »
After thinking about it, I would be willing to trade the MOBO for a new translucent blue 3" replacement trackball from HAPPS.
Thanks,
Shawn :)
« Last Edit: February 20, 2009, 01:49:01 pm by SnApRoLl »
SnApRoLl
« Reply #15 on: March 02, 2009, 11:13:33 am »
Bump
SirPeale
  • Green Mountain Man
SnApRoLl
« Reply #17 on: August 23, 2009, 02:24:03 pm »
The MOBO has been sold.
moderators please close this thread.
Thx
Ummon
« Reply #18 on: August 24, 2009, 06:30:32 pm »
Just ADD 'sold' to the title post.
Yo. Chocolate.
Stephen Hawking
