Author Topic: 82mm metal/HSS hole saw in the UK?  (Read 1766 times)
Diewrecked
  • Last login:June 20, 2012, 07:34:08 am
« on: November 24, 2008, 08:08:46 am »
Hi guys,
I've had my metal CP re-made due to the completely random position of the button holes when I got it. I've got a 29mm HSS hole saw for the buttons, however the 82mm hole saw I bought for the trackball said it was for metal but it's not. Do any of you know of anyone/anywhere selling an 82mm HSS hole saw please?
TIA all
« Last Edit: November 26, 2008, 06:39:35 am by Diewrecked »
Franco B
Re: 82mm metal/HSS hole saw in the UK?
« Reply #1 on: November 24, 2008, 11:00:04 am »
Just having a bit of a google for you.
This one will cut metal as its HSS. Its 83mm but the 0.5mm per side shouldnt matter.
Its £11.93 of ebay
There is also this adjustable one but its not cheap:
Its £64.57. It says it will cut sheet metal up to 1mm thick, im not sure how thick your CP is.
Worst case scenario if you send your CP to me I could circle interpolate the hole for you at work.
Diewrecked
« Reply #2 on: November 25, 2008, 10:09:08 am »
Wicked thanks Franco, I'll check it out.
Diewrecked
« Reply #3 on: November 26, 2008, 06:23:35 am »
Its £11.93 of ebay
This is actually identical to one I'm replacing; basically I bought the same one but under a different brand (HSS, said it would go through steel) and all it did was put a light groove in the metal when they offered it up and take the edges off the teeth!!!
Where abouts are you based please Franco? I may well take you up on this kind offer!!
Cheers
Jon
Blanka
« Reply #4 on: November 26, 2008, 06:32:56 am »
If the ring covers 1mm of the metal, you would have enough margin to cut it with a fret saw. It's pretty accurate, cheap and fast enough for this occasion.
I see that another post is about the same CP. Did you consider getting the CP CNC-ed? I think it's not worth the mess of drilling-yourself.
« Last Edit: November 26, 2008, 06:35:36 am by Blanka »
Franco B
« Reply #5 on: November 26, 2008, 06:38:42 am »
Im guessing you may have been using incorrect feeds/speeds and its taking the edges off rather than cutting.
It will probably be cheaper for you to send it to me to mill (just postage, I wont charge you anything) rather than buy another hole saw if its just a one off. Ill shoot you a PM.
