Author Topic: Looking for a .lst editor  (Read 2448 times)
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
« on: November 22, 2008, 06:01:55 pm »
Is there a .lst editor for maximus arcade FE?
« Last Edit: November 22, 2008, 10:56:20 pm by Ortizimo »
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Re: Looking for a .lst editor
« Reply #1 on: November 23, 2008, 09:15:51 am »
ROMLister can create MA lists with just about any filter. But it can't edit existing lists.
Robots will kill you.
Arcade Addiction
Ortizimo
« Reply #2 on: November 24, 2008, 01:52:38 pm »
yeah...that is basically what I need to do. I created a gamelist in one PC then I moved it to the arcade thinking it was going to work. I assume that the file holds the location address of the files it needs to run from maximus arcade since it wont work in the cab but it does in the PC i created the file. I spent lots of time going through 7000+ roms and I would hate to redo all this.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #3 on: November 24, 2008, 02:48:48 pm »
maximus lists require a pointer to where the ROMs are on your machine, so if you built the list on one machine and then moved it, you'd have to make sure the roms are physically located on the same drive\folder on the arcade machine.  otherwise i'd think it should work.
the list itself is binary and compressed, so don't go trying to edit it yourself.
Ortizimo
« Reply #4 on: November 24, 2008, 08:25:05 pm »
yes, I was thinking the same thing after I posted the previous msg. Rather just make the directory tree the same as this one then they should work...I just hope that it doesnt mind the drive letters...thnx
« Last Edit: November 24, 2008, 10:26:58 pm by Ortizimo »
