Author Topic: MameWah and VirtualNES - Problem  (Read 1676 times)
gndprx
  • Last login:September 08, 2014, 11:25:49 am
  • nope...
« on: June 18, 2003, 11:53:49 am »
Greets all.
I'm currently having a problem with MameWah 051 and VirtualNES.  When I attempt to start any rom ziped or not I receive the following error...
Error
Don't Open a (rom name) file
Then it proceeds to lock up both MameWah and VirtualNES.
I can run the roms fine if I open them directly with VirtualNES, but it crashes in the front end.
Any suggestions or ideas?
« Last Edit: June 18, 2003, 11:58:21 am by gndprx »
Re:MameWah and VirtualNES - Problem
« Reply #1 on: June 18, 2003, 01:44:49 pm »
Try running it from an actual commandline first so you know what to aim for in MAMEWAH - then alter the 'Executable Settings' in MAMEWAH to reflect this.  Check DEBUG.LOG in MAMEWAH's folder to see what MAMEWAH is doing.
gndprx
  • nope...
« Reply #2 on: June 18, 2003, 04:21:24 pm »
Thanks,
Fixed it...forgot to turn on "Pass Rom Path" in the options.  Once I did that all was good.
Nice program by the way.
« Reply #3 on: June 18, 2003, 06:54:19 pm »
Glad it worked :)
FYI the 'Send ROM Path', 'Send ROM Extension', 'Use Long Filenames' and 'Show DOS BOX' are usually the culprits if an emu is not working.
Cheers
