Author Topic: The quality of original, 80s monitors?  (Read 1390 times)
Ummon
  • Trade Count: (+13)
« on: November 18, 2008, 11:37:21 pm »
From Wiki:
"A CGA monitor is only capable of rendering 16 colors."
    I wonder if this is why the colors on original hardware monitors seem so vibrant. Perhaps there was more primary color shading?
Yo. Chocolate.
Stephen Hawking
MonMotha
Re: The quality of original, 80s monitors?
« Reply #1 on: November 18, 2008, 11:57:50 pm »
The PC CGA spec only allowed for 16 colors due to the palletizing it used.  Further, only certain colors were possible since the output wasn't actually analog.  The outputs were rather generated directly off the outputs of 74 series logic with a couple resistor dividers (some didn't evne have that, only allowing 8 colors), and that's why CGA video signals are conventionally "larger" voltage-wise than modern analog (VGA and friends) signals.
CGA monitors had analog input paths and will accept anything at the correct resolution/timing.  It's possible to display any number of colors on a CGA monitor, but the PC wasn't capable of generating more than a few at the time.  Arcades didn't have this limitation, of course.
Your 16 number also sounds wrong (too high).  I rember getting 4 on the screen at once, and a choice of 8.  EGA offered a choice of 16 at once from a larger pallete, IIRC.  Cyan, Magenta, White, and Black seemed to be the most common choice, for some ugly reason.
« Last Edit: November 19, 2008, 12:00:35 am by MonMotha »
Ummon
« Reply #2 on: November 28, 2008, 10:47:21 pm »
Notice I said I got it from Wiki. I thought original arcade color monitors were capable of many colors, but the Wiki entry caused me to wonder otherwise. That still raises the question of why the presentation of such monitors is so peculiar relative to anything else it seems. I have a 27" arcade monitor, a multisync but still, and though 15khz looks different in brightness and color quality than 31khz and up, it doesn't seem the same as original 19" arcade monitors. The latter are REALLY bright, almost like neon. Maybe it's at least partly the original RBG triad technology?
Yo. Chocolate.
Stephen Hawking
