Author Topic: Turning on a PC power supply without a mobo  (Read 2310 times)
Trebeck
  • "The Arcade" - Build #4
« on: November 15, 2008, 06:43:27 pm »
I have a pc power supply (400w) just sitting alone.  Can I turn it on without a motherboard connection?
Kevin Mullins
    • Me on Myspace
Re: Turning on a PC power supply without a mobo
« Reply #1 on: November 15, 2008, 06:47:57 pm »
There's typically a single green wire in the harness that needs tied to ground in order for it to turn on.
ideft
  • Last login:February 11, 2012, 04:06:09 pm
  • "Mister, I suspect you to be a dope fiend"
« Reply #2 on: November 15, 2008, 06:53:19 pm »
yes on main header pins.  On an ATX power source I believe it is the green wire and you have to jump it to a neutral wire(black).  Just look on the internet for the pin outs for your power source.
example:
http://pinouts.ru/Power/atxpower_pinout.shtml
look at the description for the green wire.
Bleagh
  • Last login:October 18, 2016, 04:33:25 pm
    • BLEAGH!
« Reply #3 on: November 15, 2008, 07:30:07 pm »
You don't want to run it without it powering anything.  It will burn out.  I assume you plan on powering a jamma board or something?  That should work fine.
garnerb350
    • Hyperspin
« Reply #4 on: November 17, 2008, 01:04:22 pm »
I was thinking of hooking up 2-4 cooling fans to a power supply to supply air through my cabinet enclosure. Would that be ok to run and not burn out a power supply?
« Reply #5 on: November 17, 2008, 01:08:41 pm »
A 400 watt PSU is overkill to run 2 - 4 fans...
Just get a 12 V DC wall wart and hook them up that way.
FrizzleFried
    • Idaho Garagecade
« Reply #6 on: November 17, 2008, 02:03:09 pm »
...or just buy a couple 110v fans...  :dunno
garnerb350
    • Hyperspin
« Reply #7 on: November 17, 2008, 02:48:20 pm »
The power supply is a hand me down( free)...I was just wondering what to do when i cross that road...
I was wanting to hook up the fans and also coin door lights....
HarumaN.... what does the 12 V from wally world look like?
Ginsu Victim
  • Comanche, OK -- USA
« Reply #8 on: November 17, 2008, 02:56:07 pm »
He didn't say Wal-mart, he said wall wart.  :laugh2:
« Reply #9 on: November 17, 2008, 02:59:16 pm »
Any 12 V DC transformer that you plug into a wall, usually an ugly black box that takes up too much space on an outlet, therefore a "wall wart"...
 :duckhunt
garnerb350
    • Hyperspin
« Reply #10 on: November 17, 2008, 03:02:57 pm »
 :banghead:
I'm an idiot....LOL
fatfingers
  • Got UltraStiks?™
« Reply #11 on: November 17, 2008, 03:33:11 pm »
Your fans and coin door lights will do just fine with that PSU.  I am doing just the coin door lights (well, and my marquee light) using a PSU.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
garnerb350
    • Hyperspin
« Reply #12 on: November 17, 2008, 03:48:32 pm »
Thanks!.... :notworthy:
Trebeck
« Reply #13 on: November 17, 2008, 05:44:28 pm »
Maybe I'll try the wall wart route.  Thanks all.
vputz
  • Last login:August 23, 2010, 08:16:05 am
  • I'm a llobter!
« Reply #14 on: November 19, 2008, 08:51:56 am »
I once ran a bunch of "zombie" SCSI drives (+controller) in a raid array using a non-mobo PSU by jumping the connectors with a switch.  It worked just fine for many months (and acted like it would have kept on working).  Really silly-looking; I ripped the controller and drives from an old Dell server, but since the Dell PSUs are nonstandard (and I couldn't match the connector to the SCSI board) I had to have a regular PSU for the mobo and keep the Dell PSU running as a zombie for the drives.
Worked fine for months.  It's probably overkill as mentioned, but you should be able to do it no trouble.
ark_ader
  • I glow in the dark.
« Reply #15 on: November 19, 2008, 01:28:47 pm »
You can still get those 85W AT power supplies.  They are great for lights, fans, and anything 12v.
