December 20, 2025, 02:47:03 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Monitor/Video Forum
Hantarex 9110 very sensitive vertical sync.
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Hantarex 9110 very sensitive vertical sync. (Read 3359 times)
ZMB
Trade Count:
0
Full Member
Offline
Last login:May 14, 2010, 07:46:29 pm
on:
November 13, 2008, 07:28:53 pm »
I have replaced all of the caps on a couple of my Hantarex 9110's and even though the picture is great...the sync on both are so very sensitive that the slightest touch on the trim pot for the vertical sync will cause the roll. I was wondering what else I could look for as all electrolitic caps have been replaced.
Last Edit: November 13, 2008, 07:49:30 pm by ZMB
Logged
grantspain
I personally prefer "bog trotter"
Trade Count:
+1
Full Member
Offline
Last login:August 16, 2025, 04:42:10 am
Re: Hantarex 9110 very sensitive vertical sync.
Reply #1 on:
November 14, 2008, 04:32:02 am »
what is the video source,jamma or pc?
and which pin of the input plug do you have the sync connected
Logged
ZMB
Trade Count:
0
Full Member
Offline
Reply #2 on:
November 14, 2008, 03:51:46 pm »
Jamma off of a Neo Geo. The sync is on connector CB1 if I am remembering right. The ground is on CB3 as well.
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #3 on:
November 14, 2008, 04:00:35 pm »
neo geo is snk,hantarex tend to prefer the vertical and horizonyal sync linked with snk
another thing to try is connecting a 5k resistor from the vertical sync to the video ground
Logged
ZMB
Trade Count:
0
Full Member
Offline
Reply #4 on:
November 15, 2008, 03:24:23 pm »
First let me thank you for your help. I am grateful. Secondly, I have tried that and after about a half hour or so when the chassis board heats up it will start to roll. Then it will sync again. And then it will roll again. Over and over. What in the Vertical section when heated up will cause the Vertical sync to go weak?
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #5 on:
November 15, 2008, 03:39:52 pm »
there are a few components that can cause this,use this schem
http://www.freeinfosociety.com/electronics/schemview.php?id=2245
although its a mtc9000 it should be identical
check the transistors on the sync circuits and check the voltage +12 at TP12
Logged
ZMB
Trade Count:
0
Full Member
Offline
Reply #6 on:
November 18, 2008, 06:06:03 pm »
I replaced all the trannies in the vertical circuit and check all of the resistors...All seems good but still will start to roll after an hour or so. Is there any chance that it could be IC2?
oh yeah...
the twelve meters out around 12.27 vdc
Last Edit: November 18, 2008, 06:10:22 pm by ZMB
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #7 on:
November 18, 2008, 06:20:26 pm »
12.27 is good,after 1 hour points towards a heat related problem pointing to component failure-very unlikely cap as normally its the opposite affect
ic2 is the next option,it could be breaking down internally
bugger of a fault though
Logged
qrz
Trade Count:
+1
Full Member
Offline
Last login:October 24, 2015, 03:04:15 pm
wrangling electrons since 1978
Reply #8 on:
November 20, 2008, 11:11:56 pm »
the tda2595 is likely the culprit .
looking at the ic mfg's spec (
www.alldatasheet.com
) suggests an instability in either h/v processor will affect the sync lock on the other. ( my opinion )
qrz
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
