Author Topic: Question!  (Read 990 times)
Nemss316
  • Last login:April 28, 2010, 10:30:00 am
Question!
« on: November 09, 2008, 10:44:25 pm »
Ok, I officially have my Superman arcade up and running! I've noticed though that some of my games are not displaying in full screen, but they are playing in the correct resolution. I'm assuming its a config. in the Mame.ini file that I need to change, but I've done exactly what the Ultimarc. autores instructed me to do, but when I play the game in Mala, its still not full.
Also, my Street Fighter 2, Champion Edition, Turbo, and New Challengers play a tad "jittery". They worked arcade perfect before hooking them up to my arcade monitor, is there a step I'm missing? I've noticed that Killer Instinct 1 and 2 both play this way as well, and the sound is off.
Thanks, any help would be appreciated!
Nemss316
Re: Question!******update!*****
« Reply #1 on: November 11, 2008, 12:04:21 pm »
Ok, so upon further investigation last night, the AutoRes that I ran through Ultimarc is not displaying in the correct resolution. On the command line interface, it says "sf2 -resolution not set". I did exactly what the instructions said to do on the read-me file, I will try it again when I get home and see if that works.
Has anyone else had this problem? I feel as if I'm missing a very easy step!
