Author Topic: Mala help  (Read 8193 times)
glyndawn
  • Last login:January 05, 2009, 03:37:09 am
Mala help
« on: November 09, 2008, 01:12:48 pm »
first off id like to thank every one who as helped me   :applaud:
im still having a problem with epsxe running isos within mala its fine running on its own
when i set -nogui -slowboot -loadiso it crashes and says encounted a problem
is there a way of telling mala to run just isos im really stuck
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Mala help
« Reply #1 on: November 09, 2008, 01:35:50 pm »
I don't use epsxe.  I use psx for Playstation games which works great for me within Mala.  If you decide to try psx instead, you would use the following command line:
-f "%path%\%rom%.%ext%"
glyndawn
Re: Mala help
« Reply #2 on: November 09, 2008, 01:51:23 pm »
where do i get that from
SGT
Re: Mala help
« Reply #3 on: November 09, 2008, 02:02:17 pm »
glyndawn
Re: Mala help
« Reply #4 on: November 09, 2008, 02:05:02 pm »
right got that tryed play it it say need a d3dx9.dll so got that put my bios in ran it but it goes straight to main menu memory card and cd player
glyndawn
Re: Mala help
« Reply #5 on: November 09, 2008, 02:12:33 pm »
ok got it to run a iso but it still goes to that menu part and its not full screen how do i sort that out please
glyndawn
Re: Mala help
« Reply #6 on: November 09, 2008, 02:34:43 pm »
it works great spot on
just one problem it wont go in to full screen its just windowed please tell me how to get it full screen
SGT
Re: Mala help
« Reply #7 on: November 09, 2008, 03:10:05 pm »
The -f in the command line that I gave you earlier is for full screen.
glyndawn
Re: Mala help
« Reply #8 on: November 10, 2008, 01:49:43 pm »
when i press alt entre it goes full screen no problems but when i put -f into the command line in mala the emu shuts down?
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
Re: Mala help
« Reply #9 on: November 10, 2008, 03:33:20 pm »
Hmmm...-f works fine for me using PSX 1.13.
BTW, thanks SGT for the PSX recommendation. I tried ePSXe but never could fix the huge amount of screen tearing I got, even after fooling with just about every option under the sun. I like PSX because it just works.
glyndawn
Re: Mala help
« Reply #10 on: November 10, 2008, 03:57:40 pm »
what command are you using and any pre cpmmands?
Todd H
  • It's Gameday!
Re: Mala help
« Reply #11 on: November 10, 2008, 05:57:39 pm »
No pre or post commands. Just
glyndawn
Re: Mala help
« Reply #12 on: November 11, 2008, 02:17:37 pm »
ive tryed that but no joy works without the -f but not with ??
SGT
Re: Mala help
« Reply #13 on: November 11, 2008, 06:07:58 pm »
You have a space between the f and the " don't you?
glyndawn
Re: Mala help
« Reply #14 on: November 12, 2008, 04:36:30 pm »
yes
glyndawn
Re: Mala help
« Reply #15 on: November 14, 2008, 04:20:15 am »
still not workinng with -f "%path%\%rom%.%ext%" just flashes up then off no errors or anything without the -f it works but i need to do alt entre to get full screen
im using a arcadevga graphic card and arcade monitor
SGT
Re: Mala help
« Reply #16 on: November 14, 2008, 10:17:43 am »
Are you using version 1.13 of PSX?
Try running PSX from the command line thus taking Mala out of the equation. From the PSX directory, use something like:
Code: [Select]
psxfin.exe -f "C:\PLAYSTATION IMAGES\MedalHon.img"
...replacing the path to the images and the name of a game image with yours.
If that works fine in full screen, you need to post screen shots of your Mala configuration for PSX.
glyndawn
Re: Mala help
« Reply #17 on: November 14, 2008, 11:32:24 am »
in mla when -f is there and i start the psx emu the screen just flashes and crashes
glyndawn
Re: Mala help
« Reply #18 on: November 14, 2008, 11:37:12 am »
and when iu run it run command line it says cd not usable failed to open file
SGT
Re: Mala help
« Reply #19 on: November 14, 2008, 12:36:58 pm »
Yes, I understand that.  Until you can figure out why it will not run by itself from the command line, there is no point in trying to get it to work from within Mala.
Please post:
1) the whole EXACT command line that you are trying
2) the directory from which you are running the above command line
3) the directory where your playstation images are
glyndawn
Re: Mala help
« Reply #20 on: November 14, 2008, 03:11:15 pm »
my ps1 emu is in
C:\Emulators\programs\ps1
my img are in
C:\Emulators\playstion 1 games
my cmd im trying from start run is
C:\Emulators\programs\ps1\psxfin.exe -f "C:\emulators\playstion 1 games\crash bandicoot.IMG"
but when i do this the screen just flashes on off on off on off
take out the -f and it runs
« Last Edit: November 14, 2008, 03:15:04 pm by glyndawn »
SGT
Re: Mala help
« Reply #21 on: November 14, 2008, 04:17:02 pm »
You need to actually be in the C:\Emulators\programs\ps1 directory when you run the command line. Instead of doing it  like this:
Code: [Select]
you need to do a CD command first which Changes to the directory where psxfin is located:
Code: [Select]
CD \Emulators\programs\ps1
Once you issue the above command, then issue this command:
Code: [Select]
Also check for mispellings and spacing differences.  For example, in the line above is playstion really spelled like that in your folder structure?
glyndawn
Re: Mala help
« Reply #22 on: November 16, 2008, 06:36:35 am »
from the command line with -f in the screen jsut just flashes flashes on and off again as it does in mala without -f runs fine  :'(
SGT
Re: Mala help
« Reply #23 on: November 16, 2008, 01:12:39 pm »
What version number of psx are you running?  According to the link below there was a problem with earlier versions, but it was fixed in 1.13:
http://psxemulator.proboards54.com/index.cgi?board=bugreports&action=display&thread=2238
Also in that thread, it says you CANNOT USE A CAPITAL F.  I verified this with my setup.  Make sure its a lower-case f.
« Last Edit: November 16, 2008, 01:21:44 pm by SGT »
glyndawn
Re: Mala help
« Reply #24 on: November 16, 2008, 01:31:22 pm »
its version 1.13 and im using -f lower case
SGT
Re: Mala help
« Reply #25 on: November 16, 2008, 03:52:39 pm »
Well since you cannot get the full screen mode to work outside of Mala, its obviously not a Mala issue.  I would suggest going to the psx forum to try to determine what is wrong with your setup:
