Author Topic: mala layouts  (Read 4568 times)
glyndawn
  • Last login:January 05, 2009, 03:37:09 am
mala layouts
« on: November 08, 2008, 04:46:19 pm »
i can not get the layouts to change with different emus ive read all topics but wont work ive named mame layout mame.mll and my playstation 1 layout playstation 1.mll ive ticked the tab in gui options emulator am i missing something ?   :banghead: :banghead: :banghead: :banghead: :cry: :cry: :cry: :cry: :cry: :cry: :dizzy: :dizzy: :dizzy:
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: mala layouts
« Reply #1 on: November 08, 2008, 05:50:28 pm »
tick use layout names for directory names
make sure you have playstation 1.mll in your mala folder
have your playstation 1 background in mala/playstation 1 folder
and the same for any other layouts and it should work
cheers
glyndawn
Re: mala layouts
« Reply #2 on: November 09, 2008, 04:24:56 am »
right ive started again i converted my mamewah layouts with mala layout convertor and saved them in the mala folder mame.mll and playstation 1.mll goin into mala
options
gui
layout folder C:\emulators\mala
auto layout switch ticked emulator
use layout names in directory names ticked
available layouts
mame playstion 1
standard
clicked out
but layouts arnt showing just black screen with games list and snap pic
loadman
  • Moderator
    • MaLa
Re: mala layouts
« Reply #3 on: November 09, 2008, 05:22:08 am »
The converter does not copy the required graphics.
You need to put the grahics in the MaLa folder (or sub folder depending on how you are arranged)
http://wiki.arcadecontrols.com/wiki/Mala_Layout#F.A.Q.
glyndawn
Re: mala layouts
« Reply #4 on: November 09, 2008, 05:53:35 am »
ok
i unzip mame layout to mala it creates a mame folder inside this is main pic and layout.lay
i unzip playstation to mala it creates a playstion folder inside this is main pic and layout.lay
i go in to mame folder copy the files to mala and convert layout.lay with mala layoutconvertor and name it mame.mll
i go in to playstastion folder and copy the files to mala but it wont copy as it say overwrite existing files do i need to rename them before i copy them over
dungbeetle46
Re: mala layouts
« Reply #5 on: November 09, 2008, 07:37:26 am »
make sure the mame.mll and playstation 1.mll are in the mala folder.
make sure your background image is in mala/mame amd mala/playstation 1 folders.
make sure your folders are the exact same name as you named your emulator
otherwise mala wont know which layout to pick
ie:  background pic should be in folder named mame
 playstation 1 background should be in folder named playstation 1 and your emulator under gui/other emus should be named playstation 1
(it has to be the same)
other emu = playstation 1
mll in mala folder = playstation 1.mll
playstation 1 folder = playstation 1 and is inside mala folder and has background image inside
if you do this you shouldnt have a problem. :dunno
« Last Edit: November 09, 2008, 07:54:51 am by dungbeetle46 »
glyndawn
Re: mala layouts
« Reply #6 on: November 09, 2008, 09:21:35 am »
sweeeeeeeeeeeeeeeeet got it working where can i get a jukebox layout from
dungbeetle46
Re: mala layouts
« Reply #7 on: November 09, 2008, 06:10:02 pm »
just made this if interested
