Author Topic: New Video Issue - Loss of Control  (Read 2966 times)
FrizzleFried
  • Last login:Yesterday at 03:18:56 pm
    • Idaho Garagecade
« on: November 07, 2008, 03:20:59 pm »
I've come across a new video issue in MALA.  It's actually not new,  but it's pretty minor so I never mentioned it.  Sometimes (usually at load up or when returning from an external program),  MALA becomes unresponsive for a period of time... then "catches up" after a while having saved all movements, etc in a buffer.
After really examining the behavior,  it seems that when this happens,  MALA becomes unresponsive for a single run of the video being played on screen... it then relinquishes control back to MALA at which time whatever "inputs" you put in during the unresponsive time period are then carried out (as if it was buffering them).  It happens maybe 20-30% of the time.... and again,  usually upon load up or after returning from an external program (including MAME).
loadman
  • Moderator
    • MaLa
Re: New Video Issue - Loss of Control
« Reply #1 on: November 07, 2008, 11:06:47 pm »
Thanks for the info..  ;)
I am going to try the lastest version of  VideoLab  for the next versionb of mala to see if that changes anything.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: November 17, 2008, 08:00:10 am »
It seems that the last version of VideoLab is .NET only.
Do plan to migrate Mala to .NET?
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #3 on: November 17, 2008, 10:51:46 am »
I must be seeing things because it looks like there is a Delphi version of VideoLab 3.1 at the link Loadman posted above.  Can you link to what you are talking about?
 :dizzy:
« Last Edit: November 17, 2008, 10:53:31 am by SGT »
youki
    • Atomic Front End
« Reply #4 on: November 17, 2008, 11:38:44 am »
re-reading , i think i missread.  When i saw link only on version above turbo delphi 2006 , i thought it was only for Delphi  version supporting .NET  .  But it was just link to delphi product!
Let us know Loadman.
loadman
  • Moderator
    • MaLa
« Reply #5 on: November 17, 2008, 04:23:11 pm »
I also see that the version 4.0 is 'coming soon'.  Maybe I should wait for that?  :dunno
