Author Topic: light gun help  (Read 1500 times)
noddy
  • Newbie
  • Last login:December 23, 2009, 12:57:14 am
light gun help
« on: November 05, 2008, 04:32:23 am »
i can get my hands on some old Big Buck Hunter light guns and i was wondering if it was possible to hook them up to my pc and use it through MAME.
Any advice WILL be helpfull, ;)
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: light gun help
« Reply #1 on: November 05, 2008, 06:47:07 pm »
Short answer, No.
Future looking answer: maybe but not yet, or (same product) yes but $$$ and not tested here.
Robin
Knowledge is Power
brandon
  • Last login:June 08, 2025, 02:40:01 pm
  • I <3 arcade games.
Re: light gun help
« Reply #2 on: November 06, 2008, 03:43:02 am »
Short answer, No.
$199 seems expensive at first... BUT if it supports TWO guns and also has a stereo amplifier and 24 switch inputs then that adds to the value of it..  From what I remember the arcade light guns are little more than a photocell and a switch.. so you could probably hack a molex connector on a console lightgun to work with this interface.  I think it'd be work $200 to have a solution that finally JUST worked!
BTW, what did you mean by (same product) ?  Those two products aren't the same at all.. maybe I misunderstood you..
« Last Edit: November 06, 2008, 03:59:12 am by brandon »
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
Re: light gun help
« Reply #3 on: November 06, 2008, 07:53:40 am »
They look the same to me ... both are optical gun boards produced by Nanotech.
FWIW, I am thinking that, once I clean up some of my projects, that I will break my self-imposed ban on buying stuff related to davidrfoley -- this looks to be to good to pass up and would turn my JAMMA gun cab into a nice multi-gun cab.
Working: Not Enough
Projects: Too Many
Progress: None
brandon
Re: light gun help
« Reply #4 on: November 06, 2008, 11:14:13 am »
oops.. that was before I read the entire thread.. I only got as far as the ULGI being mentioned.
