Author Topic: Making motherboard boot as soon power is present?  (Read 1841 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: November 04, 2008, 05:30:05 am »
Hey all!
Is there a way to make a motherboard boot when power is connected?
(even when the option is not in the BIOS)
I've tried the green wire with ground on the ATX, the PC boots but no image :)
Nicholas
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
Re: Making motherboard boot as soon power is present?
« Reply #1 on: November 04, 2008, 07:03:53 am »
My PC has the option in the BIOS, are you running the latest for your MB? I would make sure you have the latest and the greatest first. If there is no BIOS for your MB that will do this, I am sure there is a way to install some sorta power switch to do this.
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
« Reply #2 on: November 04, 2008, 11:28:38 am »
it's in the wiki(link)
Kevin Mullins
    • Me on Myspace
shatter
  • Last login:June 27, 2009, 02:07:12 pm
« Reply #4 on: November 04, 2008, 03:27:19 pm »
Ummon
  • Trade Count: (+13)
« Reply #5 on: November 04, 2008, 10:17:13 pm »
I thought people just got a longer set of wires that instead went to a button somewhere on the cab or panel.
Yo. Chocolate.
Stephen Hawking
AE35
AE35
« Reply #7 on: November 05, 2008, 05:17:53 am »
Well, it didn't work for me....
The cap didn't boot the mobo.
SirPeale
  • Green Mountain Man
« Reply #8 on: November 05, 2008, 07:17:15 am »
Did anything happen at all?
What size cap did you use?
AE35
« Reply #9 on: November 05, 2008, 10:32:48 am »
Hi!
Nothing at all happened...I used a 4.7uF 50V cap. While it was on I still had
to short the cap's legs with a screwdriver..and then it booted:)
ultrageek
  • Last login:August 23, 2012, 02:27:56 pm
  • If at first you don't succeed, you fail.
« Reply #10 on: November 05, 2008, 10:46:58 am »
couple of items...
1. if this works, wouldn't your PC auto-power on after a power outtage? Exposing it to spikes during a storm?
2. Wouldn't just extending the power button be a better idea? Could use it for startup as well as graceful shutdown with an ATC case/mobo. With this mod, you have to press a button or flip a switch either way right?
my $.02
the geek
« Last Edit: November 05, 2008, 10:49:07 am by ultrageek »
SirPeale
« Reply #11 on: November 05, 2008, 12:57:13 pm »
Hi!
Are you sure you got the cap on the right way?
If you did, you may have to use an even smaller cap, say 1uf.
AE35
« Reply #12 on: November 05, 2008, 06:04:47 pm »
Yes, it's on the right way.
I'll try a 1uF and get back
Thanks for your help!
Nicholas
