Author Topic: black faint bars moving in my medium resolution K 7500 help  (Read 1315 times)
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« on: November 02, 2008, 11:46:18 pm »
when i looked at the monitor it was fine, now that its at my house it has these faint black bars going from top to bottom. Any help appreciatted
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
grantspain
Re: black faint bars moving in my medium resolution K 7500 help
« Reply #1 on: November 03, 2008, 02:26:27 pm »
sounds like an earth related issue,make sure you monitor frame reads continuity to the earth pin of the machine plug
Tenn_pin
  • Last login:January 01, 2014, 06:57:02 pm
« Reply #2 on: November 08, 2008, 11:48:23 pm »
I just had the same issue with a 4600 series.  I had to run a wire from the monitor chassie to the board ground (corner screw hole) and then to the neg pole on the power supply.  Good luck.  I fought this thing for over a month after a cap kit.
R
