Author Topic: How hard would it be to convert a DKstyle cab into a DK?  (Read 1200 times)
Arcade82
  • Last login:November 01, 2008, 06:40:56 pm
« on: November 01, 2008, 06:40:56 pm »
Say I bought a cabinet that was similar to Donkey Kong (maybe even donkey kong jr or dk3) and wanted to convert it to donkey kong or double donkey kong.. what would I need to do? Get a separate arcade board?
Also would it be hard to restore the controls using new Happ controls?
"Yeah... at least he built a cabinet. I can't wait to see yours. "
aahahahaa
jimkirk
  • Last login:October 27, 2013, 01:24:15 am
  • Ahead warp factor 5 Mr. Sulu.
Re: How hard would it be to convert a DKstyle cab into a DK?
« Reply #1 on: November 07, 2008, 01:16:22 am »
You can convert a DKJR or DK3 into DK. DK & DKJR are basically the same except for board set and art.
You just change board and art,(CPO,bezel,etc.) and your good to go,assuming you are using a 2 board set.
Converting DK3 is the same process except it uses the edge connector instead of individual board connectors.
The DK3 harness will work for DK. Hope this helps.
Jim
I know who Phet is and many of you do not.
