Author Topic: Anyone try the Oscar Trigger Hack yet?  (Read 3229 times)
klutzo
  • Last login:May 27, 2005, 10:31:21 am
  • VIsit the Klutzoplex! www.klutzoplex. com
    • the klutzoplex
« on: March 05, 2002, 01:16:45 pm »
I'm mostly complete with the Trigger hack, using an old CH Flight Stick.
However I have some problems:
1) The trigger stick can spin freely, so the triggers are pointed backwards, or the wires may twist.  I've thought of drilling a hole, then putting a peg through it, but wondering about other suggestions.
2) The biggest problem, is that the Nutdriver shaft is quite small, so that the stick does not fit in 3/4 MDF... thinking I may have to do some routing, but I don't want to if I can avoid it.
suggestions folks?
klutzo
game geek, ht geek, all round geek
feel free to visit the Klutzoplex!  www.Klutzoplex.com
1UP
  • Token Junkie
    • 1UPArcade
Re: Anyone try the Oscar Trigger Hack yet?
« Reply #1 on: March 08, 2002, 03:16:34 pm »
Here's what I did:
I cut off a nail to about 3/8" long.
My other job...
klutzo
    • the klutzoplex
« Reply #2 on: March 10, 2002, 04:01:41 am »
Nice job 1up!
klutzo
Vectoraster
  • Last login:November 19, 2020, 12:55:33 pm
  • You *are* starting to annoy me.
    • The VectoRaster Network
« Reply #3 on: March 10, 2002, 08:43:12 am »
What's the purpose for this hack?  Looks interesting.  Is there a write-up on it somewhere?
johnpurs
  • Last login:April 26, 2022, 10:59:30 pm
    • John &ampamp; Mad's MAME2000 Cabinet
« Reply #4 on: March 10, 2002, 11:06:40 am »
MAME2K
Pins:Devil'sDare*Taxi*Meteor*Fireball 2*WC Soccer 94*WhiteWater*Catacomb*FunHouse*Nine Ball*Space Shuttle*Flight2000**SeaWitch*Centaur*Paragon*Big Game*F-14 Tomcat*
Zapper
  • Last login:October 07, 2006, 10:26:01 pm
  • The enemy's gate is down
« Reply #5 on: March 10, 2002, 12:13:12 pm »
Set screws might be useful for your joystick hacks. I made a trigger hack a while ago and used a little Hanson tap wrench and a Hanson 10-24 hole tap and drill bit that I picked up at Home Depot to make the holes for the set screws.
"Three warps to the Bugger homeworld"
1UP
  • Token Junkie
    • 1UPArcade
« Reply #6 on: March 10, 2002, 03:25:49 pm »
My other job...
klutzo
    • the klutzoplex
« Reply #7 on: March 11, 2002, 12:46:12 am »
I was thinking of an even simpler hack, however, I don't know how sturdy it would be.
Basically at the base of the Supers or Competitions, there is a square actuator that pushes against the microswitches.
Basucally take a U nail, and pop it through the E-ring and hot glue gun it, or drill a couple of small holes, and poke the U-mail through the holes.  So using the E-ring, it should restrict movement quite a bit.
May not be as elegent, but could be simpler.
klutzo
1UP
  • Token Junkie
    • 1UPArcade
« Reply #8 on: March 11, 2002, 01:06:52 am »
My other job...
