Author Topic: Question: Correct Tools For Laminate Covered MDF  (Read 8058 times)
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
« on: October 31, 2008, 11:14:27 pm »
I just needed confirmation on what the common consensus is as far as bits to use on laminate covered MDF.
For squaring the control panel top: Flush trim bits in a router.
For making button holes: 1-1/8" spade bit in a drill press.
For T-molding in the MDF: 1/8" slot cutter in a router.
Does this sound right?
Thanks.
Darren
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
Re: Question: Correct Tools For Laminate Covered MDF
« Reply #1 on: November 01, 2008, 09:39:44 am »
t-molding should be 1/16" slot cutter
D_Harris
« Reply #2 on: November 01, 2008, 12:11:54 pm »
My error. I just want to make sure that I am getting the correct tools.
Thanks.
Darren
« Reply #3 on: November 02, 2008, 09:53:45 am »
Slot cutter shouldn't matter anyway unless for some weird reason he is cutting a slot in the laminate.
If I were going best bits for laminate specifically I'd get a forstner bit for the button holes rather than a spade bit.  Much cleaner holes and less chance of the bit jumping out and gouging the laminate.
Franco B
« Reply #4 on: November 02, 2008, 10:35:52 am »
Helps if you read the whole post Chad ;)
I second using a forstner bit.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #5 on: November 02, 2008, 11:27:23 am »
I think Chad means that the slot cutter he uses won't be any different on a laminated board than on a painted board.  Regardless, it was an important correction to be made, though.
Best Kid iPad Apps
« Reply #6 on: November 02, 2008, 02:37:50 pm »
Yep.
Franco B
« Reply #7 on: November 03, 2008, 04:09:45 am »
My bad  :-[
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #8 on: November 03, 2008, 11:47:40 am »
I'd go with either a forstner or at least a hole saw... I would NOT use a spade bit.
I'd also use a 3/32" slot cutter.
mountain
  • Trade Count: (+9)
    • Mountain Jukeboxes
« Reply #9 on: November 04, 2008, 02:46:05 pm »
It would be best to cut the holes in the MDF before laminating. Then just use your flush trim but to open them up.
D_Harris
« Reply #10 on: November 06, 2008, 10:43:54 pm »
I'm using discarded sink cut-outs I got from a cabinet shop, so the laminate is already on them.
They are 3/4 inches thick, so I need to make sure I have the right bits.
Thanks.
Darren
« Reply #11 on: November 07, 2008, 09:48:57 am »
Are they 3/4" thick or are they 3/4" + 1/8" of laminate thick?
D_Harris
« Reply #12 on: November 07, 2008, 08:01:54 pm »
3/4" + 1/8" of laminate.
Darren
Franco B
« Reply #13 on: November 08, 2008, 06:30:30 am »
Its a shame 7/8" isn't a common size, 13/16" t-moulding wont be wide enough, you will have a 1/32" section of uncovered material either side. If you use 1" t-moulding you will have 3/64" hangover either side.
It apperas to be that you will be limited to black t-moulding. Happ Sell [7/8" black 'leather' t-moulding] and arcade-equipment.com sell [7/8" Black Smooth T-Molding]
Damn I hate imperial measurements. Ive been working with them for 10 years but there are still a PITA. 1975 was a long time ago. If it wasn't for those pesky cabs!  :P
I wonder if imperial measurements will ever disappear?
« Reply #14 on: November 08, 2008, 08:01:31 am »
People have had good results applying 1" and then trimming it down with a utility knife.  Can't see why that wouldn't work if you're careful with the cut.
D_Harris
« Reply #15 on: November 08, 2008, 02:50:06 pm »
I guess I can also route down the under-sides 1/8" all the way around.   ;D
BTW. Would a 5/8" or 3/4" long straight bit along with two passes be adequate for making the panel "perfectly" rectangular.(I used my circular saw to get the initial pieces).
Thanks.
Darren Harris
Staten Island, New York.
D_Harris
« Reply #16 on: December 06, 2008, 01:51:33 am »
Its a shame 7/8" isn't a common size, 13/16" t-moulding wont be wide enough...
Wait. isn't 3/4 + 1/8 equal to 13/16?
Why wouldn't it be wide enough?
Darren Harris
nuka1195
« Reply #17 on: December 06, 2008, 09:05:04 am »
3/4 = 12/16
1/8 = 2/16
is the laminate really 1/8 thick? that's thick laminate
D_Harris
« Reply #18 on: December 06, 2008, 12:27:06 pm »
3/4 = 12/16
1/8 = 2/16
My error. It is 1/16th.  ;D
The total thickness is definitely 13/16th.
I'm still wondering what slot cutter to get.
I have a Craftsman Router. Model #315.175040, so I assume I can use any 1/4" shank bits.
(Outside of getting 13/16" T-molding, I'm also trying to figure out what T-molding I'll need to get for a Donkey Kong cabinet).
Darren Harris
D_Harris
« Reply #19 on: December 13, 2008, 03:49:22 pm »
Here it is: http://www.t-molding.com/store/home.php?cat=24
Darren Harris
