Author Topic: Game Launcher under WinXP: problem launching  (Read 3797 times)
bigmoe
  • Last login:July 16, 2004, 04:17:54 pm
  • I forgot my mantra!
« on: June 16, 2003, 06:40:27 pm »
The FE thread reminds me:
I've been having trouble with GameLauncher under XP.  I'm using the latest binaries d/led from the GameLauncher website.
The first time I run GL, it hangs when it loads the _GL32.exe subprogram.  When I end it using Task Manager and reload GL, it runs fine.  The GL website doesn't mention any bugs like this (that I can find, anyhow).  Anyone else experience this or know what to do about it?  Do I just have a hosed install/config?  I don't see any problems with the cfg files...
What was that again?
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:Game Launcher under WinXP: problem launching
« Reply #1 on: June 16, 2003, 07:23:41 pm »
After it fails the first time and you've end tasked it... DONT start the  application again... instead take a peak at the logs and maybe post the logs here (well in the software forum) and/or maybe joing the game luancher mailing list to reach the FE author more direclty...
*Shrug*
rampy
Pyronious
  • Last login:June 04, 2021, 09:52:25 pm
  • Klatuu... Verata... Necktie.
    • Pyronious.com
« Reply #2 on: June 16, 2003, 07:39:38 pm »
Interesting, I had the same problem.  Locked up the first time and had to force quit it, but then it worked fine from then on!
Also using WindowsXP.
bigmoe
« Reply #3 on: June 17, 2003, 12:21:46 am »
Excellent advice, rampy!  (And, I note, some moderator was kind enough to move this to the Software forum without scolding...)  I didn't realize (because I didn't look) that GL kept log files.  Excellent programming practice, that.
And okay, maybe I was looking for a cheap fix...I NEED to subscribe to one more mailing list ;).
But I have done so and will report back with anything I hear.  In case anyone is interested, here are the log file samples:
Failed run (entire file)
  2003 20:59:00.978 [Info] Game Launcher v0.9.8
  2003 20:59:00.978 [Info] Allegro 4.0.1, MinGW32.s
  2003 20:59:01.038 [Info] Using screen resolution of 800x600
  2003 20:59:01.038 [Info] OS type: Windows XP
  2003 20:59:01.038 [Info] Platform: MinGW32.s
  2003 20:59:01.038 [Info] Installing joystick
  2003 20:59:02.249 [Info] Installed mouse
  2003 20:59:02.560 [Info] Sound card type: DirectSound, device 0
Successful run (top lines)
  2003 20:59:26.064 [Info] Game Launcher v0.9.8
  2003 20:59:26.064 [Info] Allegro 4.0.1, MinGW32.s
  2003 20:59:26.064 [Info] Using screen resolution of 800x600
  2003 20:59:26.074 [Info] OS type: Windows XP
  2003 20:59:26.074 [Info] Platform: MinGW32.s
  2003 20:59:26.074 [Info] Installing joystick
  2003 20:59:26.134 [Info] Installed mouse
  2003 20:59:26.244 [Info] Sound card type: DirectSound, device 0
  2003 20:59:27.526 [Info] Graphics driver: DirectDraw accel
  2003 20:59:27.526 [Info] Description: DirectDraw accel
  2003 20:59:27.526 [Info] Using double buffering
  2003 20:59:27.526 [Info] Vsync is enabled
  2003 20:59:27.536 [Info] MP3 playlist contains 18 files
  2003 20:59:27.536 [Info] Loading font: slicker.ttf
  2003 20:59:27.656 [Info] Font loaded
  2003 20:59:27.656 [Info] No HW blit: memory bitmap for movable bitmap
  2003 20:59:27.666 [Info] No HW blit: memory bitmap for movable bitmap
  2003 20:59:28.407 [Info] Starting engine loop
I've played around with the relevant graphics card settings in the .cfg files, but can't seem to make any difference.
Of course, it COULD be a bug in Windows....nah...
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re: Game Launcher under WinXP: problem launching
« Reply #4 on: March 01, 2010, 03:32:18 pm »
I know this is a 7-year-old bump, but this thread is one of the only hits when searching google for this issue.  :P
I'm actually having the EXACT problem the original post describes where _GL32.exe hangs.  I actually moved MAME and Game Launcher from one computer to another.  I actually took the slave hard drive out of the old computer (it just had MAME, Daphne, and Game Launcher on it) and am now slaving it off of the new computer, so it's in pretty much the same configuration as it was.  Both computers are running Windows XP.
I've also tried re-installing (well, re-extracting GLaunch), and there's nothing at all in the log files that shows anything errors except that it never initializes that "Graphics driver: DirectDraw accel"
Anyone have any revelations in the past seven years?  ;D
