Author Topic: Wiring Coin Box  (Read 1877 times)
heebeegb
  • Last login:June 01, 2009, 09:56:57 pm
    • HeeBeeGB
Wiring Coin Box
« on: October 20, 2008, 03:22:16 pm »
So the wiring of the coin micro switches was easy.
Problem is hooking the two 6V counters.
and also the solenoids.
Also, the lighting is antiquated. I found a shop that sells LED equivalent.
I understand that the LEDs are 20O hms and that I-Pac will run 10 Ohms.
So how do I hook up voltage to the counters and he lights.
I read a few good postings on this forum, but for someone that is very ignorant when it comes to wiring and electronics... well I feel rather stupid.
Anyway, any help.
thanks
Franco B
Re: Wiring Coin Box
« Reply #1 on: October 20, 2008, 03:41:40 pm »
You could use a adjustable/6v wall wart to power the 6v counters.
For the coin door lamps/LEDs just tap into either the 5v or 12v from a spare PSU molex. Part of [this] tutuorial/round-up may help you to wire them.
Good luck :)
heebeegb
    • HeeBeeGB
Re: Wiring Coin Box
« Reply #2 on: October 20, 2008, 07:27:12 pm »
Some places suggested running the LEDs off off the 5V from I-PAC.
can I run a 6Volt counter of a 5Volt i_pac output?
where is the output?
is there danger of frying my I-pac?
Not to mention the solenoids?
can I run them all of the 5V?
do I have to atttach each respectively to different outputs?
I was also told that too much to the LEDs shortens their lifespan.
would the 5V I-pac be too much?
do I need to regulate it somehow?
I am ignorant with electronics.
Stupid questions, but figured this was the best people and place to ask. ;D
« Last Edit: October 20, 2008, 07:46:11 pm by heebeegb »
venkman
  • Last login:January 28, 2013, 02:44:28 am
Re: Wiring Coin Box
« Reply #3 on: October 21, 2008, 06:13:40 am »
heebeegb
    • HeeBeeGB
Re: Wiring Coin Box
« Reply #4 on: October 23, 2008, 10:49:02 pm »
What significance does the diode represent?
there was suggestion in this discussion's third reply by Sarge:
http://forum.arcadecontrols.com/index.php?topic=77573.0
What does the diode do?
I just wish to understand what it means.
P.S. I did finally get the counter to work in the wiring by running the Voltage to the counter's positive, and then the counter ground to the microswitch Normaly Open (NO). This isolated the counter so that only when the microswitch was triggered could a cuircuit be created and BANG! a numerical progression of 25cents can now occur.
Thanks to this forum!
and all those contributing.
sarge
  • Last login:April 27, 2015, 01:42:54 pm
Re: Wiring Coin Box
« Reply #5 on: October 23, 2008, 11:46:33 pm »
The diode needs to be there to protect the any circuits in line with the meter.
Here is an article that explains this to some degree.
                               http://www.kpsec.freeuk.com/components/relay.htm
Same reason they use diodes on coils in pinball machines.
heebeegb
    • HeeBeeGB
Re: Wiring Coin Box
« Reply #6 on: October 25, 2008, 11:30:50 pm »
Here is the best I can do to illustrate my wiring configuration.
The counters actuate with the coin microswitches.
It was great.
But then I try the I-Pac and the counters don't work.
Where am I going wrong?
UPDATE!!!
I was running the Voltage for the counters through the 12V
I moved it to the 5V and All is fine now.
I wonder if the Ipac was in danger at the time.
I understand that it runs at 5V :S
The 12V can now be dedicated to the Solenoids and Lights :)
« Last Edit: October 26, 2008, 02:46:13 am by heebeegb »
venkman
Re: Wiring Coin Box
« Reply #7 on: October 26, 2008, 06:52:32 am »
 :dunno who knew!
thanks for the update.
