Author Topic: Virtual Cd rom drives  (Read 2062 times)
Sprucemoose
  • Last login:March 23, 2009, 03:56:10 pm
  • You Spent How Much?!
« on: June 15, 2003, 07:09:09 pm »
What software do you guys recommend for setting up virtual cd rom drive (I believe thats what it is called) on your computer so you can download PC games, or anything that requires the cd, off the hard drive without CD.  I have read in former post people talk about this and have seen type of software fo sale that do this, but I was wondering if anyone could shed some light on the subject.   What software is good/bad etc..  Do I have the concept correct?
spectre
  • -- banned --
  • Last login:April 07, 2004, 08:45:11 am
  • -- banned --
Re:Virtual Cd rom drives
« Reply #1 on: June 15, 2003, 09:26:03 pm »
daemon tools...
-- banned --
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: June 15, 2003, 09:31:02 pm »
Hmmm, if I remember the big program for hackers in the mid-90s was a program called virtalcd, or virtualdrive.
spectre
  • -- banned --
  • -- banned --
« Reply #3 on: June 15, 2003, 11:58:33 pm »
daemon tools...
-- banned --
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
« Reply #4 on: June 16, 2003, 12:00:53 am »
ya Daemon Tools, very easy to setup and i'v never had any problems with it. and you can add multiple drives,
and it supports many image types.
Sprucemoose
« Reply #5 on: June 16, 2003, 11:26:01 am »
Cool, I just downloaded it daemon tools and it works great.  Thanks for the info guys.  Can you only add 4 drives?  Or is that the max with Daemon tools?
Syxx
  • Bling Bling
« Reply #6 on: June 16, 2003, 12:40:31 pm »
i believe 4 is the max. there is some addon things for them i think but that was a long time ago, they might not work with the newer releases [which are much better then the old ones]
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
« Reply #7 on: June 16, 2003, 06:33:36 pm »
What I like about it is that you can mount and un-mount cd's from the command line. So I just have my FE launch a batch file to mount the cd, launch the game and then dismount the cd. Works great , I have had no trouble with Daemon tools.
                         Slug54
Sprucemoose
« Reply #8 on: June 17, 2003, 10:43:47 am »
Slug54,
How do you set up a batch file and what do you input into it?  Forgive my ignorance, I have never done that before.
liquid8
  • Last login:January 08, 2026, 02:01:16 pm
  • I working on it.. it'll be a while.
« Reply #9 on: June 17, 2003, 11:33:28 am »
that is the COOLEST program ever.. can't believe i hadn't seen this yet... Thanks!
LiQuiD8
slug54
    • Arcade Extreme
« Reply #10 on: June 17, 2003, 09:22:03 pm »
Slug54,
First off a Batch file is just a simple text file
with each command typed on a seperate line
exactly like you would type it at the command line.
The important thing is it has to be renamed to a
.bat extention instead of .txt
here is a copy of my ydkjcd.bat file.
This file is used to launch one of my You Don't Know Jack CD images. I just call the batch file from my FE.
Code: [Select]
@echo off
c:
cd\progra~1
cd d-tools
daemon.exe -unmount 0
daemon.exe -mount 0,d:\cdimage\ydkj.ccd
You should be able to copy this to your own .bat file
and just change the path and file name of the cd image. That is if you used the standard install directory for Daemon tools.
FYI the "@echo off" just keeps the coomands from showing on the screen. remove it for trouble shooting your commands by placing REM before it.
also my cd images have a .ccd because I use Clone CD to make them yours may be a .ISO file.
                         Good Luck
                             Slug
Sprucemoose
« Reply #11 on: June 18, 2003, 09:13:15 am »
Slug,
Thanks for taking the time to help me out.  I will try and set it up tonight and see how it works.
