Author Topic: ultimarc arcade vga install help needed I am frustrated  (Read 2528 times)
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« on: October 16, 2008, 11:28:08 pm »
So i have tried to install the arcade vga card today in my PC. I followed the directions and my screen looks like its flickering or moving. I have tried everything and I am frankly just frustarted. Someone please help me out. I have the card currently hooked up to my computer monitor, because if I hook it up to the arcade monitor I cannot read anything that comes up.
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
Re: ultimarc arcade vga install help needed I am frustrated
« Reply #1 on: October 17, 2008, 04:24:13 am »
install the resolution driver program that came on the ultimark cd, but make sure 1st you uninstall all the video drivers already on your system using the uninstall prog on ati site, then reinstall drivers from ultimarc cd.
then change your resolution to lower, thats what i did, still get a bit of flickering as its interlaced
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #2 on: October 17, 2008, 06:15:11 am »
If you are still stuck drop me an email on andy@ultimarc.com
Standard res arcade monitors cannot display more than approx 288 lines so this is the reason for the interlacing on resolutions above 288 (hence flicker). Its a monitor limitation. But lower resolutions, for gaming, should be fine.
Andy
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« Reply #3 on: October 17, 2008, 12:56:11 pm »
Also make sure you are plugging the monitor into the VGA port of the card and not the DVI port as this might not give you a picture.
ctozzi
« Reply #4 on: October 17, 2008, 05:20:41 pm »
Thanks Andy. Andy is the best he guided me through the install. It was a combination of a few things.
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
Ummon
  • Trade Count: (+13)
« Reply #5 on: October 17, 2008, 09:46:25 pm »
Perchance you might share them?
Yo. Chocolate.
Stephen Hawking
ctozzi
« Reply #6 on: October 17, 2008, 09:59:18 pm »
the install for the driver needed to be forced, and after going to the dvice mgr ultimarc is not listed so we picked the microsoft driver in the list and installed it from the disk provided. It was a little backwards but worked.
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
Ummon
« Reply #7 on: October 19, 2008, 11:18:40 pm »
Ah, thanks.
Yo. Chocolate.
Stephen Hawking
