Author Topic: Entire path displays in PC games layout *solved*  (Read 4063 times)
Knievel
    • Knievel Kustoms
« on: October 10, 2008, 12:46:48 pm »
Quick question..I hope :)
I've got a PC Games list set up now and on my layout instead of getting the name of the program it's displaying the entire path.
For example instead of displaying 'Hamsterball' I'm getting "C:\PC Games\Hamsterball\hamsterball.exe"
Am I using the wrong thing in that text box? I'm using ~g_name like on all my other layouts.
« Last Edit: October 16, 2008, 02:56:49 am by loadman »
XyloSesame
  • Last login:September 17, 2024, 05:57:04 pm
  • the creepy prince guy...
    • The Nightingale Theater
Re: Entire path displays in PC games layout
« Reply #1 on: October 10, 2008, 01:17:30 pm »
Are you using Howard's PC Games Utility and Launcher?
I've had great success using this with MaLa and gamelists...
Knievel
    • Knievel Kustoms
« Reply #2 on: October 11, 2008, 10:14:01 am »
No I was just using the 'folder of shortcuts' method like I did with Mamewah..but Mamewah just displayed the name.
It works great except for this issue.
I guess I could try it though. Thanks for the link. :)
XyloSesame
« Reply #3 on: October 11, 2008, 12:19:38 pm »
It was pretty easy to set up once i figured out what I needed for each game... I've got a single PC ROMS folder in which I place the .pcg files; I've named them what I want to show in my gamelist. In MaLa, my "Other Emulator" tab for PC games only looks for .pcg files and produces a nice clean list.
My .pcg files point to Closemul .bat files so I can escape the games. In a couple of cases, the Closemul .bat points to 3DAnalyze for pixel-shading emulation. Closemul opens 3Danalyze, then passes a command to run the game, finally closing 3Danalyze after the game begins.
Works like a charm.
loadman
  • Moderator
    • MaLa
« Reply #4 on: October 11, 2008, 07:51:51 pm »
That is weird.
I just did it quickly (with notpepad as the game) and it just showed the name .
See attached pics for my setup
Knievel
    • Knievel Kustoms
« Reply #5 on: October 13, 2008, 09:56:07 pm »
A picture is worth 1000 words as they say.
Here's what I'm talking about, the text under my snap..
« Last Edit: October 14, 2008, 12:52:40 am by Knievel »
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #6 on: October 14, 2008, 01:50:24 am »
~g_name is the 'rom' name. Use ~g_description instead. Thats the titel of the game.
loadman
  • Moderator
    • MaLa
« Reply #7 on: October 14, 2008, 01:59:13 am »
What he said.   :applaud:
Thanks Swindus  ;D
Knievel
    • Knievel Kustoms
« Reply #8 on: October 14, 2008, 10:59:58 am »
Fixed, thanks guys. Coulda sworn I tried that before. :P
loadman
  • Moderator
    • MaLa
« Reply #9 on: October 14, 2008, 07:54:29 pm »
Don't worry.  I didn't pick up on it on your first post  ::)
