Author Topic: general xp question  (Read 870 times)
ideft
  • Last login:February 11, 2012, 04:06:09 pm
  • "Mister, I suspect you to be a dope fiend"
general xp question
« on: October 09, 2008, 09:01:06 pm »
I know I have come across this at one point in time, but I can't remember if it was here or not.
Sometimes my son kills the power on my cab without shutting it down first.  On the next power up I get the screen informing me that windows didn't shut down properly and gives me the three choices.  Is there anyway to disable this from happening??
DrFrag
  • Last login:December 15, 2011, 10:14:47 am
    • MAME Cab Worklog
Re: general xp question
« Reply #1 on: October 09, 2008, 09:08:51 pm »
Go to Start -> Settings -> Control Panel -> System -> Advanced -> Startup and Recovery Settings.  You can change the time it displays the options.
« Reply #2 on: October 10, 2008, 01:34:25 am »
How is you son cutting the power?  Is he just pressing the power button or using a power strip to literally turn it off.  Unplugging it perhaps?
If he's pressing the power button, you can set Windows XP to safely shut down automatically.  It will be equivalent of pressing ALT-F4 to exit what ever programs are running and then clicking on Shutdown and Turn Off.  But it does it all in one shot very quickly.  This will shut it down properly and prevent the errors coming up when you first start the computer.
You can enable this feature by going to your control panel, performance and maintenance, power options and then click on the Advanced tab.  There you will see a section aptly named... power buttons.  Change the drop down to say "Shut down".  Now it's all set so that when you press it, it will shut down completely.
Hope this helped.
~ DeLuSioNaL
