Author Topic: Help me build a jig for repetative miter cuts?  (Read 3432 times)
dmworking247
  • Last login:July 14, 2024, 01:30:59 pm
« on: October 06, 2008, 08:47:47 am »
I'm potentially going to be building a LOT of control panel boxes. The beauty of the material I'm using is that its preprimed, prebevelled architrave.
The thing thats costing me the most time however is doing the 45' miter cuts.
I have:
  • A compound mitre saw (but its currently a rough blade that I don't want to keep changing, and I also dont have a spare A$100 for a 100-tooth blade).
  • A jigsaw (difficult to get EXACTLY 45' especially if I have to keep re-setting the tool to its regular 90'), and its also difficult to cut these panels in a perfect straight line without a jig/guide.
  • A router (trying to figure out a way that I could build a jig using a patern bit to make perfect repeatable miter cuts).
Here's an example of the 'boxes' I'm trying to make repeatedly. Note the mitre joins in each corner. The MDF is roughly 1/2" thick and 2 2/3" tall (I'm hopeless with imperial).
I'd like to be able to cut perfect 45' miter cuts for two 'set' lengths of MDF with a minimum of setup/configuration. Can anybody suggest the right tool/how I'd build a jig to make life easier?
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
Re: Help me build a jig for repetative miter cuts?
« Reply #1 on: October 06, 2008, 10:11:32 am »
1. miter saw with a stop block
2. router mounted in a table with a 45 degree bit and a miter gauge.
dmworking247
« Reply #2 on: October 06, 2008, 08:26:28 pm »
Ah! For some reason I had never thought about a 45' bit for the router (duh!). Thats given me something to think about, thanks!
Franco B
« Reply #3 on: October 07, 2008, 10:48:11 am »
I was racking my brains trying to think up a way for you cut them with a router, I had never thought about a 45 degree bit either! Good plan :)
Twinpanther
  • Last login:January 12, 2016, 02:03:51 pm
  • Yukihime
« Reply #4 on: October 07, 2008, 12:54:35 pm »
And if you wanna be fancy.
45° Lock Miter Bit
OMG, where have you guys been all my life?!
Blanka
« Reply #5 on: October 07, 2008, 02:09:51 pm »
45° Lock Miter Bit
But with a lock bit, it won't work on the rounded edges. The joint won't be OK.
nuka1195
« Reply #6 on: October 07, 2008, 03:52:56 pm »
it should work fine, just round after putting it together.
Blanka
« Reply #7 on: October 08, 2008, 03:19:30 pm »
nuka1195
« Reply #8 on: October 08, 2008, 03:55:44 pm »
i still don't see an issue, plus glue ups with that router bit should be easier.
Blanka
« Reply #9 on: October 08, 2008, 04:19:40 pm »
If it is pre-bevelled, you cannot make nice connections with the lock bit!
This is what will happen:
Blanka
« Reply #10 on: October 08, 2008, 04:24:03 pm »
This is probably easiest for quick perfect 45 degree mitters (with the not shown angle-guide attached, or by turning the table in 45 degrees)
A table saw is also perfect for it, but it is harder to get the length of the parts perfect to the last 1/5th mm.
Guess I was half the time behind this machine when making the graduation town plan models  :laugh:
« Last Edit: October 08, 2008, 04:26:44 pm by Blanka »
shardian
« Reply #11 on: October 10, 2008, 09:53:32 am »
Your Miter saw is the absolute best option for this. All you need is to rig up a stop block. Set up the block once, adjust the saw once, then bang out 100 pieces in 15 minutes. It is worth investing in a decent blade.
