Author Topic: unknown chassis 14 "  (Read 6262 times)
doubleD
  • Last login:September 24, 2009, 01:40:44 pm
« on: October 02, 2008, 12:49:35 pm »
unknown chassis  with a 13 pin neck pcb,,checked all known sites no help. printed on back of board "KHC GAME SCANBOARD 1415/2115 Ver.1.0., On the neck pcb printed in corner 14 " video V1.0. any help much appreciated .thanks!
http://i468.photobucket.com/albums/rr42/doubledowned/arcade/chassis14a001.jpg
« Last Edit: October 04, 2008, 03:31:22 pm by doubleD »
doubleD
Re: unknown chassis 14 " ??????
« Reply #1 on: October 03, 2008, 11:39:25 am »
wow i thought someone would have commented by now ,something, anything, i guess everyones as puzzled as i am  :dizzy:, Are there any known monitors that use a 13 pin neck pcb? only thing ive found out is most likely high res because of the LM 1203N , again any help in identifying this chassis is appreciated.
grantspain
« Reply #2 on: October 03, 2008, 01:23:56 pm »
lm1203 are used many different res chassis
i have never seen that chassis before
Ken Layton
  • Guru
  • Technician
« Reply #3 on: October 03, 2008, 02:55:28 pm »
The chassis has a Taiwan look to it. Could be a Jen Shinn.
It's got a switching power supply in it so no isolation transformer would be needed.
The LM1203N chip on the neckboard is used by many monitor and television set manufacturers. Definitely LM1203 is used with different resolutions.
doubleD
« Reply #4 on: October 03, 2008, 03:14:29 pm »
 ;D you are both correct,, some more googling and youll never believe ive found out what it goes too .found an image of the back inside of a Taito Classics Bartop..and to my surprise there was the mysterious chassis! i would have never believed it had i not seen it with my own eyes.now if i could just find schematics on it and a tube ill be good to go! thanks for the input grantspain and ken.
doubleD
Re: unknown chassis 14 " Identified
« Reply #5 on: October 04, 2008, 10:31:14 am »
turns out to be an Irico 37SX110Y22-DC05
Ken Layton
  • Guru
  • Technician
« Reply #6 on: October 04, 2008, 11:31:51 am »
What resolution is it?
doubleD
« Reply #7 on: October 04, 2008, 11:54:38 am »
ken all i can find is that the game was jamma wired, and cga . info came from http://web.archive.org/web/20061102175106/www.retroblast.com/reviews/GameRoomClassicsCabinet-08012006-02.html so i assume its standard res but cant find anything on the monitor its self.
Ken Layton
  • Guru
  • Technician
« Reply #8 on: October 04, 2008, 02:13:53 pm »
Irico made the picture tube. The tube # is 37SX110Y22-DC05. The 37 means 37cm diagonal measurement across face of tube.
This still does not identify the chassis though.
Kevin Mullins
    • Me on Myspace
« Reply #9 on: October 04, 2008, 03:30:32 pm »
Appears to be all China made stuff...... including the bartop game in which they might be found.
So the chassis is probably made by someone like :
Irico - Royal Electronic Information Co.
or
Shenzhen Irico-Royal Information Electronics Co.Ltd
The tube is listed as a 15.75khz though.... CGA ..... so at least that much is known.
Seems to be used in several 14" televisions overseas.
doubleD
« Reply #10 on: October 04, 2008, 03:36:48 pm »
true kevin thats the same info ive come across . difficult monitor and chassis to find info on. sorry ken ,didnt mean to post incorrect info.got ahead of myself .
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #11 on: October 05, 2008, 07:21:56 pm »
is there a problem with the chassis , or just trying to ID it ?
if it is chinese made , info WILL be difficult to find, IF at all  . just as it is with most chinese electronics   :angry:
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #12 on: October 05, 2008, 07:47:17 pm »
Based on the picture, very simple board a few comments:
- Ken is right switch mode supply no iso required. Feed back is through an optic isolator to regulate the voltage so likely PWM supply
- It is almost certainly CGA/Standard res only.
- The Ha 11235 is for processing the sync etc.
As I mentioned seems like a simple board, and asked earlier in the thread, is there a problem or just tring to find out who made it??
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
doubleD
« Reply #13 on: October 06, 2008, 03:01:28 pm »
yes was trying to id it and get what ever info anyone had on it . chassis is all i have no tube yet. thanks for all the input everyone ,every little bit helps!
