Author Topic: What type of Monitor Glass?  (Read 1556 times)
koinsatx
  • Last login:April 26, 2021, 11:46:31 am
« on: September 29, 2008, 08:45:46 pm »
How important is it for the glass covering the monitor to be tempered?
Is it worth the extra money to have it tempered or can I use just regular glass?
Also do most people recommend a tinted glass as opposed to clear?
Thanks - Doing my first cab and still learning.
Ken Layton
  • Guru
  • Technician
Re: What type of Monitor Glass?
« Reply #1 on: September 30, 2008, 12:22:52 am »
I never use tempered. Just get plate glass with the edges sanded.
Tinted glass should never be used with optical gun games as it interferes with the shooting. Personally, I would not use tinted for any game.
Blanka
« Reply #2 on: September 30, 2008, 03:00:56 am »
Tempered is for the easily tempered. If you are going to slam on your glass, pick tempered. If it is only a 10 bucks upgrade, go for it. Not only are the breaks safer, but the the glass is much stronger as well. Tinted is not needed. That only dims your image.
Dustin Mustangs
  • Last login:September 14, 2017, 11:43:18 am
  • Cut the sheet!
    • My Site
« Reply #3 on: September 30, 2008, 10:48:05 am »
I put the popular greylight 14 on my cab and have no problems with my act labs lightguns on account of it.  It does dim the image a bit but I was able to get most, if not all, of that back by adjusting the monitor.  In my opinion you either need tinted glass or some type of monitor bezel.  I will say the greylight does a good job of hiding everything behind the glass other then the image.  I also had it tempered.  My trackball is positioned such that the glass does get bashed pretty often with games like golden tee so I considered it a requirement.  I think I paid $75 otd for it...
« Last Edit: September 30, 2008, 10:50:07 am by Dustin Mustangs »
TOK
  • The Game Always Wins
« Reply #4 on: September 30, 2008, 12:05:32 pm »
I prefer tinted glass/plexi. I think it makes the machine look more polished and I like the way it makes the images look.
Like the other poster said, I bump the brightness and contrast just a bit.
