Author Topic: cant get daphne to work  (Read 5757 times)
Martijn
  • Akira!
    • ModMyBox
« on: September 24, 2008, 04:40:42 am »
titel says it all.
i got daphne 1.0 and video images from newsgroups.
it loads when i do command line dapnhe.exe ace nolpd
and shows some credit things, but no game
when i try to run it with just dapnhe.exe ace
it says i need to specify what laserdisc or drive i use
help..
Havok
  • Trade Count: (+17)
Re: cant get daphne to work
« Reply #1 on: September 27, 2008, 10:52:18 pm »
Try this:
daphne.exe ace vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -bank 1 00000001 -sound_buffer 2048 -fullscreen
Or, and easier way is to grab AtomicFE, and my Daphne Plug and Play module...
bigdog1977
  • Last login:June 16, 2009, 01:32:48 am
« Reply #2 on: September 28, 2008, 02:46:11 am »
aaaachuuuuuu Torrent! Excuse me! :laugh2:
These arnt the droids your looking for...
Martijn
  • Akira!
    • ModMyBox
« Reply #3 on: September 28, 2008, 07:09:12 am »
thnx, ill try them
Martijn
  • Akira!
    • ModMyBox
« Reply #4 on: September 30, 2008, 10:41:01 am »
tried the command line
it loads and then says cant find frame file ace.txt
i looked in the framefile dir. there is a file called ace_framefile.txt
i renamed it to ace.txt
then i loaded again
now it plays all the movies very fast after each other
then the intro starts and i cant do anything.
 :dizzy:
Martijn
  • Akira!
    • ModMyBox
« Reply #5 on: September 30, 2008, 10:55:55 am »
ok, after i was patient it loaded more and it was playable.  :angel:
its hard to configure for maximus arcade with this command line
Havok
« Reply #6 on: October 03, 2008, 01:36:50 am »
Here's the other command line entries, if you are feeling frisky and want to configure all of them:
astron vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -bank 1 00000000 -sound_buffer 2048 -fullscreen
badlands vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -bank 1 10000001 -sound_buffer 2048 -fullscreen
bega vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -bank 1 00000100 -sound_buffer 2048 -fullscreen
cliff vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -bank 1 01000000 -bank 2 00000000 -bank 3 01111000 -sound_buffer 2048 -fullscreen
cobra vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -bank 1 01000000 -sound_buffer 2048 -fullscreen
lair vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 11111001 -bank 1 00100111 -sound_buffer 2048 -fullscreen
lair2 vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -fullscreen
esh vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -fullscreen
galaxy vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -bank 1 00000000 -sound_buffer 2048 -fullscreen
gpworld vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -fullscreen
interstellar vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000001 -bank 1 00000000 -sound_buffer 2048 -fullscreen
mach3 vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 01000001 -sound_buffer 2048 -fullscreen
roadblaster vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -bank 1 00000000 -sound_buffer 2048 -fullscreen
sdq vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000001 -bank 1 00000000 -sound_buffer 2048 -fullscreen
tq vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00010000 -sound_buffer 2048 -fullscreen
uvt vldp -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -sound_buffer 2048 -fullscreen
Ummon
  • Trade Count: (+13)
« Reply #7 on: October 03, 2008, 05:36:31 pm »
I don't know why you'd use the cmd for Daphne, at least with MA. Just program all your games via DaphneLoader, select that for the exe in MA - bang it automatically finds everything - click okay in the MA manager, and off you go to play!
Yo. Chocolate.
Stephen Hawking
Havok
« Reply #8 on: October 03, 2008, 06:46:40 pm »
So MA generates a MS list for all the games, or are you saying point to DaphneLoader and then use DaphneLoader to choose the game?
Martijn
  • Akira!
    • ModMyBox
« Reply #9 on: October 04, 2008, 04:01:30 am »
confused aswell  :dunno
Nologic
  • Last login:November 21, 2008, 03:22:57 pm
« Reply #10 on: October 04, 2008, 05:23:42 am »
Well here is a simple loader that should work with any FE:
http://www.filesend.net/download.php?f=d71054c3e091f23f809cb63b59600da3
1. Extract it into your Daphne folder
2. Run DaphneLoader.exe & configure your games, on each game under the Advance tab enable Display Command line
3. In Daphne Loader click Start, you will see the command line that is to be used....copy everything but "daphne.exe ", and past it into My_Daphne_Loader.ini as a new line of text.
4. At the start of each line enter a name you wish to use to reference this game...followed by a equals sign "="
5. After copying the command line click Cancel.
6. Create a folder full of dumby text or batch files that have matching names as to what you used in the INI file
7. Direct your FE to use My_Daphne_Loader.exe as the executable, & your folder full of dumby files as your Rom folder.
8. Your FE command line should look something like:
My_Daphne_Loader.exe "[ROM]"
Now if everything goes right...your game of choice will be playing, to exit over course Esc will do the trick but also if you are using Gamepads\Joysticks you can also exit with the joystick\POV in the upper left hand corner & buttons 4, 5 & 6 all held at the same time.
« Last Edit: October 04, 2008, 05:26:45 am by Nologic »
"Pinky, you've left the lens cap of your mind on again." - The Brain
« Reply #11 on: October 05, 2008, 02:14:12 am »
With Maximus Arcade, all you have to do is configure every game in the DaphneLoader.exe program (comes with Daphne).  Once everything is the way you like it and it runs properly in Daphneloader, you simply configure Maximus Arcade by pointing it to the Daphneloader.exe file.
Done.
Ummon
« Reply #12 on: October 05, 2008, 05:39:12 pm »
Yeah, like re-iterated by DeL. (The order stated by both of us makes it quite obvious I would think.) I mean, it's so quick and easy to check: select Daphneloader as the exe in the MA manager - don't even care about any particular game's settings, just leave them default for the moment - and then close/save and run a game. That will show it works. Then, if you want to specify games' settings, go and do it in Daphneloader.
Yo. Chocolate.
Stephen Hawking
